Chandler's Battleship of Doom
Discussion in '2nd Gen. Builds (2005-2015)' started by ChandlerDOOM, Aug 21, 2014.
  1. Apr 2, 2017 at 5:45 PM
    #2561
    ChandlerDOOM
    ChandlerDOOM [OP] International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    They look pretty small imo
    Just checked, no ko2s in a 40. But god damn MTRs are expensive as fuck in a 40"
    Talked to Austin a bit, your axle is a 8x170mm right? I need to get a complete parts list together so I can wrap my head around the cost
    Acerwin[QUOTED] likes this.
  2. Apr 2, 2017 at 6:11 PM
    #2562
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Nittos are available in 40s :stirthepot: they'd be a good DD tire
    I believe so
  3. Apr 2, 2017 at 8:49 PM
    #2563
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    shocked you still have the 35s? no one wanted them
  4. Apr 2, 2017 at 10:31 PM
    #2564
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Didn't see any of those updates on your frame until now. They were pretty bent or of shape! I still have to pull off my bumper and straighten everything out as well... Thinking about doing something similar to what you're thinking as well
    ChandlerDOOM[OP] and Pirhett like this.
  5. Apr 2, 2017 at 10:36 PM
    #2565
    Pirhett
    Rhett
    San Diego
    Stock...
    what happened to his or your frame?!
  6. Apr 3, 2017 at 5:03 AM
    #2566
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    I put them up but not super motivated to sell them because I partially wanted to keep them.
    I might be plating it soon, I think I may just overlay something thicker and keep the factory studs for the time being but that should get me by for the mean time
    Frame ends for the bumper didn't play well with hard winching
    Pirhett[QUOTED] likes this.
  7. Apr 3, 2017 at 7:31 AM
    #2567
    Pirhett
    Rhett
    San Diego
    Stock...
    oh dang, did you have the reinforcement bracket for the front bumper?
  8. Apr 3, 2017 at 9:35 AM
    #2568
    WormSquirts
    Braeden
    BC
    Yeah, hard winching for @ChandlerDOOM and just a hard pull on mine with a snatch strap ended up bending the front mounts. I think Chandlers is a lot worse than mine though, mine is just bent on the one side
    would you put the steel on the backside or the front? the front body mount is so close that it's going to be tricky to work around. Would have been nice to be able to just put an angle plate from the frame to the mount with a gusset.
  9. Apr 3, 2017 at 2:53 PM
    #2569
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Yes, it kept the bottom together but not the top, it's the first that Tyler has seen really do what happened
    So what I'm thinking is a plate overlay the factory plate, the backside welded all the way around and little gussets on the side. I'd like to figure another mounting pointy up higher in the bumper as well
  10. Apr 3, 2017 at 3:50 PM
    #2570
    WormSquirts
    Braeden
    BC
    Its funny that its the first time tyler has seen this happen, and it happened to two of us! I havent talked to pelfreybilt at all about it though.
    another mount point would definitely help stop it from being bent down. I'm still worried about the aluminum mounting brackets though. It will certainly be a lot stronger with the frame mounts stiffened up, but on mine, the single bolt on the inside pulled a big dimple into the aluminum. I'm thinking that it would help a lot to have much bigger and sturdier "washers" as well for the front of the bumper to sandwich the aluminum in steel. Then any stress would either have to rip the welds right off, or rip the threads right off the frame bolts. Better bolts would be the only solution then of course.
  11. Apr 3, 2017 at 3:56 PM
    #2571
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Yeah bigger bolts and washers would probably help, I know of the dimples you speak of.
    WormSquirts[QUOTED] likes this.
  12. Apr 4, 2017 at 9:50 AM
    #2572
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Yeah, Ray's truck is gnarly!! I want to put tons front and rear eventually but want to keep the full bed without cutting into it. Been keeping an eye on all the cantilever/bell crank designs out there and hope to go that route in the rear. I know Wyatt at RST isn't to fond of doing that but that's the best way to get the outcome I'm looking for. Something similar to what Off-Road Evolution is doing with their Double throwdown in the rear would be perfect for a Taco.
    I called Dynatrac the other day asking if they planned on making an ABS compatible straight front for our 2nd gens. They said there has been interest out there but nothing on their end to figure it out. They said it could be done an might be something they'd do in the future if the market was there. I say call them and light the fire under their ass. I know it's not a huge deal to many to eliminate the ABS, but to some it matters and in certain states the ECU needs to be code free to pass inspection.
    Also asked about the recent price increase of their Tacoma rear and stated the initial price was a mistake and shouldn't have been posted at that price. Guess we should have gotten one while the price was down.
  13. Apr 4, 2017 at 10:23 AM
    #2573
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Yeah we should have. But before I think it was the same as Currie. Need a few extra things. Since the price increase it comes with everything but gears and locker. So price will be about the same once it's ready to be thrown under the truck. How ever I'll still go with Currie because of the tilted housing allowing more ground clearance.
  14. Apr 4, 2017 at 10:26 AM
    #2574
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    what did you regear to? I am going to 4.56s at the end of the month
  15. Apr 4, 2017 at 10:52 AM
    #2575
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    488 but I haven't put much time in with the 35s and 488s only 37s, this weekend I'm going to try and get the truck out so I'll have a better idea how the gears are with 35s.
    fatfurious2[QUOTED] likes this.
  16. Apr 4, 2017 at 10:54 AM
    #2576
    fatfurious2
    David
    Ashburn, VA
    I have 33s with no plans for going larger. I hope I made the right decision with the gears
  17. Apr 4, 2017 at 10:58 AM
    #2577
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    456 is probably a good choice
  18. Apr 4, 2017 at 4:19 PM
    #2578
    WormSquirts
    Braeden
    BC
    I'd be curious on your impression with 4.88s on 35s. As you know, I just ordered 35s, but I'm not sure when I'll have money for gears (and lockers).
  19. Apr 4, 2017 at 4:21 PM
    #2579
    fatfurious2
    David
    Ashburn, VA
    gears are expensive. I am paying $1900 installed, for front and rear, without the front locker. The front locker would add an additional $800.
  20. Apr 4, 2017 at 4:22 PM
    #2580
    WormSquirts
    Braeden
    BC
    sheeeeitttt... yeah, so I should modify that to "(and locker.)"
