Chandler's Battleship of Doom
Discussion in '2nd Gen. Builds (2005-2015)' started by ChandlerDOOM, Aug 21, 2014.
  1. Jan 16, 2016 at 12:50 AM
    #541
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    That's about what mine have been. Never coated them and not showing any signs of anything.
    dakotasyota and Sje1124[QUOTED] like this.
  2. Jan 16, 2016 at 1:56 PM
    #542
    ChandlerDOOM
    ChandlerDOOM [OP] International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Does anyone know how much movement you should have in your carrier bearing? Also any sure way of seeing if your front wheel bearing is going bad? I get this odd vibe in the front end when cornering kind of noisy, not sure if its my tires or wheel bearing. I could throw my stock wheels on but would rather not if I don't have to
  3. Jan 16, 2016 at 2:59 PM
    #543
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Carrier bearing has some play, maybe like a 1/4"-1/2" cause it's surrounded by a rubber bushing, is that torn at all?
    Jack up the truck and wiggle wheel at the 12/6 o'clock position, should be no play if the wheel bearing is good. You can also rotate the wheel and see if you get any noise like a groaning/gritty, if so it could be bad.
    Sounds like a bad wheel bearing though if the side receiving the load from cornering is noisy.
  4. Jan 16, 2016 at 3:10 PM
    #544
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    No tears on the CB but has some play, I was messing with it while I was under the truck spraying the fluid film and wasn't sure. Ill try that method for the bearing, I'm nearing 60k so chances are I need to replace them anyways especially since its been on 33s since 13k and 35s since 38k
    Bsheriff11[QUOTED] likes this.
  5. Jan 17, 2016 at 11:54 AM
    #545
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Ill just leave this here
  6. Jan 17, 2016 at 11:55 AM
    #546
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  7. Jan 17, 2016 at 11:57 AM
    #547
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
  8. Jan 17, 2016 at 11:59 AM
    #548
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Also just paid for my share of the Shok sound deadener, I was on the fence about it because its one of those comfort items. But after driving in the wind for 2 hours barely being able to hear anything I said fuck it, hopefully it helps
    GARSHA91 likes this.
  9. Jan 17, 2016 at 12:07 PM
    #549
    GARSHA91
    Chicago
    Just turn the music up :thumbsup:
  10. Jan 17, 2016 at 12:12 PM
    #550
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Oh trust me I do, I should have taken a video its loud as fuck when the wind is going
  11. Jan 17, 2016 at 2:06 PM
    #551
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Damn you make me wish we wasn't friends...so I didn't have to look at this....I guess I'll be adding these to my list eventually except kings :D
  12. Jan 17, 2016 at 4:49 PM
    #552
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Haha Icon will suffice for bumps, I picked it up for 20% off
  13. Jan 17, 2016 at 5:06 PM
    #553
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Damn that's not bad.
  14. Jan 17, 2016 at 5:11 PM
    #554
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Autoanything runs a 20% off all the time and they sell a bunch of stuff, some isn't included in the sale but most is
    Acerwin[QUOTED] likes this.
  15. Jan 17, 2016 at 5:13 PM
    #555
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Damn I'll have to check them out.
  16. Jan 18, 2016 at 9:01 AM
    #556
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    It's 5 degrees outside but I really want to put my bumps on
  17. Jan 18, 2016 at 12:04 PM
    #557
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    Last time (a week ago) I checked ICON coilovers were't covered. Interesting to know that the hydro bumps are.
    It's unfortunate that you haven't received a response from ICON. They were very prompt and great to deal with when I had to send in one my rear shocks for a warranty. I'd also be curious to see the discoloration you are referring to on the shocks themselves.
    Acerwin likes this.
  18. Jan 18, 2016 at 12:13 PM
    #558
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    So are them bumps installed yet :D
  19. Jan 18, 2016 at 3:08 PM
    #559
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Fuck no what a pain in the dick, seriously took forever trying to get those rivets out. I got the driver side bump plate off but couldn't get the bottom rivets punched out since their isn't much room to work with. The top ones I drilled through and gave it a whack or two and they popped out
    I think my best bet is to flex out the rear so I can get my drill under
  20. Jan 18, 2016 at 3:09 PM
    #560
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sounds like a bitch
