Change Filter When Changing Trans Fluid, This Is The Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2013.
  1. Apr 21, 2013 at 9:18 PM
    parfleet
    parfleet [OP] Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    My 05 Tacoma PreRunner, 4.0 is coming up on 100,000 miles and I am preparing to change the trans fluid. Which by the way is no big deal and I have seen tons of video on a simple drain and refill. The question is, should I change the filter as well. The trans pan is fully accessible and I am certain that I could remove it and change the filter. I called a trans shop and asked about should I change the filter. The answer was quite surprising. I was told that little, if anything, would be gained by changing the filter as it is not a filter at all but a screen. Heck, I even emailed scottykilmer.com and he recommended a simple drain and refill. The local dealer would do the trans service in the following manner: 1) Open the drain plug to drain the fluid. 2) Leaving the drain plug off, remove the fill plug and run 1 quart of fluid through. This would clean the trans filter (screen). 3) Reinstall the drain plug. 4) Now remove the check plug. 5) Add 3.2 quarts of fluid through the fill plug which should result in the check plug location slightly leaking fluid. 6) Reinsert the check plug and tighten. 7) Lastly reinsert the fill plug and tighten. That's it! That's all they would do for just over $100. So should I do the filter...I'm inclined to. What say ye?
  2. Apr 21, 2013 at 11:53 PM
    gearcruncher
    Canadain bumper technician
    Aisn Warner transmissions have for the most part always used a screen rather than a cloth style filter . Not sure on their reasoning behind this , but most debris gets caught by the magnet on the bottom of the pan . Assuming they beleive that more particles floating around in the fluid is better than a cloth filter creating a restriction of fluid .
    Whenever I have removed a screen style filter , it was always clean even with blown planetary gearing laying in the pan .
  3. Apr 22, 2013 at 12:00 AM
    S.B.
    S.B. Well-Known Member
    Sean
    SD, CA Now in Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    SAW 2.0s, Wheeler's 3-leaf AAL, On Board Air, 255/85/16 Cooper Discover S/T, CBI Sliders, Built right UCAs, 6" Harbor Freight Lights (converted to HIDs), KC Slim Lights.
    I would, they probably are cheap.
  4. Apr 22, 2013 at 4:40 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    05 double cab SR5 4x4
    TRD air filter, exhaust tip, tinted windows, upgraded grill, OEM LED tail lights, LED DTRL'S, Matts 123 skid plate, 4Runner Mirrors, 17 inch OEM 4runner wheels
    I asked my Toyota mechanic, who worked for toyota over 15 years and has his own shop, and he said drain and refill, no need to clean the screen unless you are having problems with it and no need to flush it if you drain and refill every 30 to 40k when you change your diff. gear oils.
  5. May 2, 2013 at 7:05 PM
    Callahan2010
    Callahan2010 Member
    The Colony, Texas
    2010 Tacoma
    Just my two cents, Im a diesel mechanic. If it were a cloth or paper filter I would change it. If it is a screen, do not mess with it, unless you just like spending money.
