change front brakes
Discussion in 'Technical Chat' started by neilc, Jul 11, 2012.
  1. Jul 11, 2012 at 11:25 AM
    neilc
    neilc [OP] Member
    Neil
    massachusetts
    2009 tacoma 4x4 sport
    brush guard,step up rails
    how do you change front pads and calipers on a 2009 tacoma
  2. Jul 11, 2012 at 11:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm assuming you mean pads and rotors, not pads and calipers?
    Here's a thread on pad change:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/38025-diy-front-brake-pad-change.html
    To change the rotors, you'll need to remove the 2 bolts holding the caliper in place, then you'll notice that the OEM rotors have 2 threaded holes in them, those are jacking points. Get a bolt that fits those holes and start cranking evenly on each one til the old rotor pops off. When you put the new rotor in place, put a healthy amount of neverseize behind the rotor to prevent it from rusting to the hub.
  3. Jul 11, 2012 at 4:23 PM
    neilc
    neilc [OP] Member
    Neil
    massachusetts
    ya,i meant pads and rotors,i hear you can turn the rotors down on these trucks but i think ill just change them
  4. Jul 11, 2012 at 4:44 PM
    Pugga
    Massachusetts
    I believe you have them turned but the price of new is so close to the cost of having them turned that it's not cost effective.
    If you go to Autozone, their pads have a lifetime warranty on them. Yes, lifetime warranty on a wear part. I purchased new pads and rotors from them and it cost me about $150ish.
  5. Jul 11, 2012 at 4:56 PM
    joesmith
    joesmith Well-Known Member
    Alaska
    2005 Access Cab 4x4
    I have never had that much luck with turning the rotors. I just buy new ones to go with my new brake pads. I did mine the other weekend.
    To remove the rotors you could use a M8 bolt in the threaded holes (OEM rotors only) or just use a big rubber mallet and loosen them up (which is what I did).
