Change oil when warm or cold?
Discussion in 'Technical Chat' started by Buffalofan, May 8, 2008.
  1. May 8, 2008 at 3:49 PM
    Buffalofan
    Buffalofan [OP] Well-Known Member
    Chicago
    2001 Tacoma V6 SR5 TRD Package Lunar Mist
    I usually change my oil in the morning before I drive my truck. I happened to be looking something up on Toyota.com and saw instructions for changing oil.
    I took a peak and the directions said to run the car/truck to normal temp, then wait 1/2 hour and then change the oil.
    I would think you would want to change it cold that way ALL(besides oil filter) the oil would be in the pan. To me the other way doesn't make sense.
  2. May 8, 2008 at 3:54 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    Warm because the oil is warm and thinner and non sticks to the pan when draining out
  3. May 8, 2008 at 3:56 PM
    missileman125fw
    missileman125fw Well-Known Member
    In my very simple terms, cold oil doesn't flow good. When the oil is warm it will empty better. Does that make any sense? Sometimes I confuse myself!!
  4. May 8, 2008 at 3:58 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    I prefer to change it cold. I leave my Taco parked for a couple hours to let all the oil drain to the pan, and also it allows time for the oil filter to drain.
  5. May 8, 2008 at 4:22 PM
    Buffalofan
    Chicago
    I don't seem to have a problem with the flow, it comes out pretty quick as it is. I would just think you are not getting all the oil out since it has just lubricated the engine.
    Also the filters nowadays have it where it keeps oil in them, which sucks because the filter on the 2001 has a horrible location being pointed up and then you have to turn it on its side to make it fit in order to get it out.
  6. May 8, 2008 at 4:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Warm is probably better for easier flow... BTW, WTH is th is posted in the Tacoma Videos forum?
  7. May 9, 2008 at 4:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You don't necessarily want it at 'running temp' - as the oil will be scorching hot. 30 minutes is only long enough to allow the oil to drain down into the pan....the oil will still be pretty damn hot even after 30 minutes.
    Generally, I'll run the truck for a few minutes and then wait about 30 minutes for it to drain. The oil is luke warm and easier to handle.
  8. May 9, 2008 at 6:49 AM
    Buffalofan
    Chicago
    It's posted here because I am an idiot. I was on my way to a different forum when something caught my eye. Then I forgot and thought I was in the forum I was initially going to and posted the thread.
    Thanks for pointing it out...:D
  9. May 9, 2008 at 9:43 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I was always told change it HOT because by then all the viscous slippiest characteristics of the old oil are in order..so that it will more readily all drop to the pan and out the hole:)
  10. May 9, 2008 at 7:54 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    I change mine at normal operating temps. I do my oil changes at work so I drive 20 miles to work the park the truck, get my filter wrench, drain pan, new oil and filter out, then get under the car and pull the plug. The oil is definitely hot, but you just gotta get the plug out fast ;)
  11. May 9, 2008 at 7:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you got that right!!!
    when the oil is hot(or warm for those who dont like burned fingers:eek:), best time to change it because all the real dirty oil comes out then....doesnt settle like it does when its cold.
  12. May 10, 2008 at 8:08 AM
    Buffalofan
    Chicago
    I guess I will be changing it when its hot/warm for now on.
  13. May 15, 2008 at 7:07 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    This has always worked for me. I'm also actually looking forward to the next change to see how the Fumoto valve works at keeping the hot oil off the arm on that last twist of the drain plug.
    Ended up dropping the plug in the hot oil because of that more than once.
  14. May 18, 2008 at 2:18 PM
    Nocturnall
    Nocturnall Member
    Peoria, AZ
    Bone Stock
    I usually dump half a quart of fresh oil in the fill hole to flush out any crap on the bottom of the pan and do my changes when it's cold. I really don't like working on a truck with hot exhaust, lines, everything then super hot oil.
  15. May 18, 2008 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The contaminates in the oil settle when the engine is cold. By running a 1/2 quart into the engine and out the pan, the oil is mearly running over the conaminated oil and out the drain hole without takeing any contaminated oil with it. Best thing to do is change oil when engine is at or near opperating temp. I use some long welding gloves that I put a rubber coating on. I belive the coating I used is called "Plasti dip". I have yet to be burned when changing my oil.:)
  16. May 18, 2008 at 3:49 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    The idea that all the oil is coming out hot or cold is not correct. About 10 percent of the oil is stuck in ports and the pump and recesses in the heads and cam phazers. The trick is to change the oil at regular intervals. If you do a lot of stop and go, change it more often. When oil isnt operated at temp very long (lack of highway time) it tends to accumulate moisture and blowby gasses (acidic). Good oil keeps this stuff from taking out bearings and varnishing parts. We run amsoil in a top-stock motor and every year wonder if we realy need bearings when we re-build. Aside from rod stretch, the internals are always mint. I recomend synthetic lubricants to anyone interested in keeping an engine tight. Mobil-1 is a good product. To go above that, Amsoil,royal purple, redline or any of the high end synthetics. If you can find it BG is also a great synthetic.
  17. May 18, 2008 at 3:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good info!
  18. May 18, 2008 at 4:19 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    +2!!! Hey Ell-what do you think about "MOC" oil additive? Been using it since my truck was new. Toyota here carries it so I'm assuming it's good stuff??
  19. May 18, 2008 at 4:43 PM
    Nocturnall
    Nocturnall Member
    Peoria, AZ
    Bone Stock
    On the topic of amsoil anyone tried the 25k mile/ 1 yr filter they have? Anyone go extended oil change intervals with full synthetic oil?
  20. May 18, 2008 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wouldnt ever go that long on an oil filter no matter how good the oil and filter supposedly are. every 5k with me......running pennzoil platinum and mobil1 filter.
    peace of mind for me anyway.
