Change Power Steering Fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by tr0gd0r, Apr 6, 2009.
  1. Apr 6, 2009 at 1:06 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    Does anyone know how to change the power steering fluid in the 1st gen tacoma? Could someone link a how-to?
    Also, how many quarts of fluid will I need for the change?
  2. Apr 6, 2009 at 2:15 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    yea my steering rack has a leak so i have to add fluid almost weekly and when i go mudding i usually change it afterwards.
    I dont know what the official way is, but i just stick the return hose (the one from the rack to the reservoir) in a bottle and turn the car on, then turn the wheel back and forth a few times. this usually empties the system. then i turn it off and add more fluid. i didnt find any capacity specs in my manuals, so just fill the reservoir, then turn on the ehgine and turn the wheel both ways and add more as needed.
    anyone feel free to correct anything you think i got wrong
  3. Apr 6, 2009 at 2:16 PM
    STLharry
    Harry
    VT
    oh and yea i think it uses less than 1 quart, but again, i am not completely sure
  4. Apr 7, 2009 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My husband and I did it with our 96.....We actually drained, flushed, and filled it. This is how we did it:
    Jack up the front end of the truck.
    Disconnect low pressure line (lines with hose clamps on them). Drain old fluid.
    Reconnect the low pressure line.
    We bought some cheap bo-bo brand ATF, filled up the resevoir with that. Start the truck and slowly cycle the steering lock to lock a few times. This gets the fluid circulating through the system and also bleeds the air out. Make sure the resevoir DOES NOT go dry.
    Drain the cheap fluid out (same as above). Put in the good fluid (we used Mobile 1 ATF) and repeat the same procedure of steering slowly lock-to-lock. Keep an eye on the resevoir. Turning the steering wheel is actually bleeding the system. You have to keep an eye on the resevoir to make sure it DOES NOT go dry. Air bubbles will burp out (bleed out) at the resevoir.
    When the bubbles stop coming up - top off the resevoir as needed.
    Check the fluid level a day later.
  5. Apr 7, 2009 at 7:58 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    nice how-to Janster :)
  6. Apr 7, 2009 at 9:13 AM
    Bing0
    Bing0 Member
    02 4WD Limited Icons
    Icons, Cepek Rims, Bilstein Rears, Deck plate mod, Complete Sound Deadener with foam, GPS Kenwood
    You need to be careful when you do this because if your pump
    (which operates at relatively high pressure)
    pumps dry, you can severely damage your system.
    I have a 2002 and synthetic Mobil 1 ATF fluid is the optimum choice for my truck in my opinion.
    Bing0
  7. Apr 7, 2009 at 1:05 PM
    tr0gd0r
    Pullman, WA
    I just did a drain and refill of my transmission with Mobil 1 Synthetic ATF and have 2 extra quarts so I was going to use some in my power steering. Thanks for the tips guys. I will be doing this sometime this week.
    Did you disconnect the low pressure line at the top near the reservoir or at the bottom on the rack?
  8. Apr 7, 2009 at 2:55 PM
    Janster
    Jandy
    Lancaster, PA
    Bottom.....so you can drop it into a bucket and catch the fluids.
  9. Dec 17, 2012 at 6:41 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
    Sub'd
  10. Dec 17, 2012 at 6:51 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I have a gear oil syringe that I used to suck out of the reservoir. Worked well and easy to refill with the same amount of fluid if you have measurements on the syringe.
  11. Oct 17, 2015 at 1:56 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Also interested in what low pressure line you disconnected.
  12. Oct 17, 2015 at 5:28 PM
    Janster
    Jandy
    Lancaster, PA
    It's been many years -since 2012 that I posted that ... so I'm a little rustyand honestly don't remember.
    High pressure lines are the rubber lines with the permanently crimped metal ends on them.
    Low pressure lines are just rubber hoses with a hose clamp on the end.
  13. Oct 17, 2015 at 7:51 PM
    beavis87
    El Paso
    '10 Silver TRD OR
    I appreciate it. I seem to be going through threads on this that are at least 3 years old. Must not be a common thing to do very often for Tacoma owners eventhough the haynes manual says to do it every 2 years. Wish there was a pictoral write up. Maybe I should make one...
  14. Oct 17, 2015 at 7:54 PM
    thewarriordinghy
    thewarriordinghy Kyle Busch Truck
    Ben
    Georgia
    2007 Kyle Busch Tacoma
    plastidipped rims, Toyota trucks emblem, jesus fish, strictly street spoiler, NASCAR cat-back, URD cold air intake, Aftermarket TRD offroad stickers, Kyle Busch license plate bracket, URD Ypipe, custom manifold spacer, URD headers Tundra racing drop kit
    yes you should
  15. Oct 17, 2015 at 11:34 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Its easiest to pull the return line at the reservoir, then route the hose toward the ground to empty the system into a container.
    Follow jansters info, but instead of turning the engine on to empty the system just leave the steering unlocked and grab the tire its self and manually steer it. Thatll push the old fluid out without running the risk of possibly running the pump dry for a second or two. Im sure the pump wouldnt be hurt but this way you dont give it the chance to...
