Change Rear Block
Discussion in 'Suspension' started by Tacomotion, Jun 4, 2008.
  1. Jun 4, 2008 at 9:48 AM
    Tacomotion
    Tacomotion [OP] Member
    '07,TRD Sport
    3" Revtek lift,Heated leather seats fron and rear
    I have a Revteck 3" lift installed by the dealer when I bought the truck. The rear block is 1 3/4" . I have a friend that works a lathe and can make me a 2 1/2" block. My question is, is the Aluminum a specific grade for blocks, and how hard is it to change out the rear blocks? (Me not being a mechanic)
  2. Jun 4, 2008 at 9:56 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I don't know about the grade, but I'd be leaning towards steel over aluminum. You will also need new u-bolts. These complete kits are relatively cheap. I'd probably buy a complete setup.
  3. Jun 4, 2008 at 10:07 AM
    Tacomotion
    '07,TRD Sport
    How Cheap is cheap?.........and how difficult is it to install? Does anything else need to be adjusted?
  4. Jun 4, 2008 at 10:09 AM
    Motorkopf
    Motorkopf Conservative
    Victorville, CA
    05 PreRunner SR5 2.7 Manual
    3" Toytec lift, Susp TSB, Detroit True Trac, Carr side steps.
    Switching out the rear block is really simple. You could probably do it in about an hour. I think you can actually download the installation instructions from Revtec's website- if not, try Toytec (same procedures).
  5. Jun 4, 2008 at 10:18 AM
    Tacomotion
    '07,TRD Sport
    Thanks!
