Change startup image on 2020 tacoma trd offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Supermansami, Feb 13, 2020.
  1. Feb 13, 2020 at 12:20 PM
    Supermansami
    Supermansami [OP] Member
    Sami
    2020 toyota tacoma trd offroad
    I have tried the instructions on other forums to change the startup image but do not see an option when inserting the flash drive. Can you change the startup image on a 2020 tacoma?
  2. Feb 13, 2020 at 12:27 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I believe I heard some 2020 owners bitching about it not being available
    philth, Skydvrr and Doobfucious like this.
  3. Feb 13, 2020 at 12:36 PM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I can tell you this much, make SURE you use a SMALL or very low capacity flash drive and not something that has capacity of several GBs. I am talking about something that has maybe 50mg or less of capacity. I can't remember where I saw it, but this is a requirement to be able to change the images on the Entune system. I had a similar problem as no option coming up too, but then I remembered seeing somewhere that you need a very small flash drive in order to do it. I actually went to the local 99cent store, and bought a flash drive that only held 10mg. I loaded the images on there, and when I inserted it into the USB port under the radio, everything went smoothly with the install. So I would definitely try the SMALL flash drive first. I am betting that is the problem...
    mrjordan415 likes this.
  4. Feb 13, 2020 at 2:00 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    first did you name the files as instructed? displayoffimage and startupimage...
    insert usb an touch the gear wheel then general then custom image then transfer = yes then image = Ok.
    max size the screen can take is 1920X1080.
    also i remember something about "is the usb formatted correctly" maybe someone can further describe that.
  5. Feb 13, 2020 at 2:41 PM
    ParadigmShifter
    ParadigmShifter Well-Known Member
    Ian
    Scottsdale, AZ
    2020 Tacoma TRD Off-Road - White
    Another 2020 owner here. At this time that feature is unavailable to 2020 Tacomas. Might come later in an update.
    Umpire Taco, Petex46f3 and NEIPA27 like this.
  6. Feb 13, 2020 at 2:51 PM
    HeritageTRD
    HeritageTRD Well-Known Member
    Washington
    98 4runner 3.4 V6 5spd MT Anthracite Metallic
    265/75/R16 BFG KO2's on Akuza 359 wheels - Sport Hood Conversion - Trail Gear 60" Rock Sliders - Rola Roof Rack - Custom Front Recovery Points - Hella 500 fogs - Flowmaster 50 series - Smoked Tails - Clear Corner & Turn Lenses - 5% Tint - GT Exact Seat Covers - Kenwood DVD & Alpine Speakers.
    I was wanting to do this when I get my truck....hopefully it gets figured out/becomes an option to customize again. It would be sweet if it stayed on just a touch longer on startup. Customizable duration time would be cool too...
    WCTRDTaco likes this.
  7. Feb 13, 2020 at 6:00 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    That sucks, why would they do that? different head units in the 2020?
  8. Feb 13, 2020 at 6:11 PM
    HeritageTRD
    Washington
    Yes...
  9. Feb 13, 2020 at 6:27 PM
    Supermansami
    Sami
    Thanks I
    Thank you I was thinking I was special or something.
  10. Feb 17, 2020 at 10:04 AM
    NEIPA27
    NEIPA27 Well-Known Member
    Florida
    2020 OR
    crap. I really wanted to do this too.
  11. Feb 17, 2020 at 10:27 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    They also removed the Entune App Suite because the 2020 has CarPlay and Android Auto. Boneheads!
  12. Mar 9, 2020 at 2:22 PM
    SmilingBob
    SmilingBob New Member
    2020 Tacoma TRD Off Road
    Another 2020 Tacoma TRD Off Road owner here...
    I can also confirm that you cannot (at this time) change the Display Off Image or Display Startup Image on the new Entune 3.0 head unit. I tried to get a definitive answer from Toyota's customer experience hotline, and spent about 45 minutes on hold only to be told to call back in because their tech people weren't available on Saturdays.
    After going through several videos on YouTube, I came across one titled, "Toyota Entune 3.0 Head Unit Tour." In it, the presenter walks through all of the settings and gives brief explanations of each. You can see that he doesn't have the options to "Customize Display Off Image" or "Customize Startup Image" either.
    I think what's confusing a lot of people (myself included) is that there are two different issues people are running into:
    1. Those that have the option available, but don't know how to use it (i.e. not formatted as FAT32, improperly named file folders, unsupported image format etc.)
    2. Those that don't have the feature at all
    Most replies I've read assume the first scenario, which suggests that inserting a properly formatted USB drive will cause the options to appear (which isn't the case). I hope the additional information is useful to somebody!
    Hoksamoen, Flkracker and Devious6 like this.
  13. Sep 8, 2020 at 6:42 PM
    kphandley
    kphandley New Member
    Kevin
    Portland, OR
    2014 Tacoma
    I have a 2020 4Runner I purchased in August. The new head unit does not have the change image options.
  14. Oct 18, 2020 at 10:36 AM
    Petex46f3
    Petex46f3 Member
    Bay Area
    2020 Tacoma TRD off-road DCLB - quicksand
    not available on 2020 tacoma purchased Nov 2020, build date of october
  15. Dec 10, 2020 at 1:16 PM
    Drawblood
    Drawblood Member
    2021 White Taco TRD Loaded
    Also not available on my 2021, just purchased :(
  16. Dec 10, 2020 at 6:53 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I ran into this with my MIL's new RAV with the Entune 3.0 HU. I was going to surprise her with photos of the kids and it didn't work. It's such a weird feature to delete.
  17. Jan 27, 2021 at 2:23 PM
    CowrockMtn
    CowrockMtn Member
    Paul
    Tacoma Off-road 2021
    Black Cat Exhaust
    It's not on my 2021 Tacoma Off-Road. Why would they remove an option like this?
  18. Jan 27, 2021 at 2:27 PM
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    Has anyone said you can't do it on 2020+ models since the head unit is different?
  19. Jan 27, 2021 at 2:29 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Damn...
    Well im glad i had that option on my 18.
    :headbang:
  20. Jan 27, 2021 at 2:35 PM
    rcwhat
    rcwhat Well-Known Member
    Jeff
    20 trd or
    Read the thread and find out
