Change tire size to correct speedo?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdhughes, Mar 24, 2011.
  1. Mar 24, 2011 at 7:47 AM
    jdhughes
    jdhughes [OP] Member
    Minnesota
    11 Base 4x4
    Allpro rear bumper (Line-Xed), rock sliders(Line-Xed), dipped grill,
    From the factory my speedo reads 4mph fast, and the dealership hasn't been any help. I'm getting new rims and tires anyways, so does anyone know of a site that has an "old tire size to new tire size and the speedo change because of it" calculator?
    Thanks for the help.
    JD
  2. Mar 24, 2011 at 7:51 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
  3. Mar 24, 2011 at 7:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    In a lot of cases (atleast my truck), the speedometer that you see (the dial) is wrong but the information in the computer is accurate. I have a Scanguage II and it displays MPH taken directly from the computer. The dial that you see in the dash is calibrated wrong. So, you just have to keep that in mind..... or get a Scanguage II (you can calibrate it to the proper tire size and it'll show proper MPH).
    Use www.google.com and search "Tire size calculator" (or similar).
    LIke this one - although I don't know how accurate the info is on here.
    http://www.tacomaworld.com/forum/tirecalc.php
  4. Mar 24, 2011 at 7:57 AM
    jdhughes
    Minnesota
    11 Base 4x4
    My brother has a scan tool, so I'll check that tonight, also I'll check the forums to see if there's anything about calibrating the needle.
    Thanks everyone.
    JD
  5. Mar 24, 2011 at 8:11 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The simple answer is yes... To my eyes, the speedometer on my 2010 DC Tacoma looked to be about 3 mph too fast (compared to my GPS)... When I replaced the 265/70-16 Rugged Fails with 265/75-16 Dynapros (1" taller tire), the speedometer read RIGHT ON!
  6. Mar 24, 2011 at 8:26 AM
    jdhughes
    Minnesota
    11 Base 4x4
    Perfect! I wanted to go with a 265/75-16 to begin with, and my factory tire is a 245/75-16, so the added height difference should get me the 4mph.
    Thanks David.
    JD
  7. Mar 24, 2011 at 8:29 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    since i got my 285's my spedo is spot on (or so gps says)
  8. Mar 24, 2011 at 11:28 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    In my experiences, the speedos are always faster with stock tyres. Why?
    I think its a big scam. Our Jeep liberty speedo was off almost 6% (verified with GPS). The tacoma is 3%. Jeep wouldnt do anything stating it was how they all were. We even test drove the exact same model for comparison.
    When you think about it your being ripped off for mileage that isnt there, and exiting warranty coverage before you should. We threw the biggest tyres on that Liberty and it corrected it to about 1% fast. Have to check what my tire upgrade did to my Tacoma...
  9. Mar 24, 2011 at 12:02 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you search, you'll find what David said is exactly true. And since you wanted to go to that size anyway, problem solved.
  10. Mar 24, 2011 at 12:52 PM
    jdhughes
    Minnesota
    11 Base 4x4
    I never thought about it that why, but it does make sense, and in my experience I've only seen it in newer vehicles. My '05 Jeep GC was 2mph off @70, but my '02 Olds Aurora with 252k miles is spot-on and so is my '86 Camaro w/275k. Granted the shown miles on odometer vs. actual driven miles aren't drastically different, but the potential for more and sooner services is there.
  11. Mar 24, 2011 at 12:54 PM
    jdhughes
    Minnesota
    11 Base 4x4
    Yes Sir it is, didn't think it would work out so smoothly though.
  12. Mar 24, 2011 at 5:08 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Ok so by upgarding my tyres from 265 65 17s to 275 70 17s I effectively changed the spedometer from being 3% fast to 1-2% slow! 5% change! sweet!
  13. Mar 24, 2011 at 5:14 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Agreed.
  14. Mar 24, 2011 at 9:05 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
  15. Mar 25, 2011 at 10:41 AM
    jdhughes
    Minnesota
    11 Base 4x4
    Burn some rubber and get that thing down to dead on.
  16. Mar 25, 2011 at 5:57 PM
    05Moose
    Jim
    :burnrubber:
  17. Mar 25, 2011 at 6:46 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    It's been said on here many times that even tho the speedometer is off, the odometer is spot on so your maint. schedule will still be accurate
  18. Mar 26, 2011 at 7:19 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Never! I get longer warranty coverage this way! haha
  19. Apr 18, 2011 at 7:35 AM
    jdhughes
    Minnesota
    11 Base 4x4
    Just got the new rims and tires put on. Bought the black rock crawler rims from wheelersoffroad.com and ordered a set of Kumho KL78's from the local tire shop. The speedo is dead on.
  20. Apr 18, 2011 at 7:39 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ^^this. bigger tires = speedo reads slower = ODO now reads slower
