Change Transmission Filter or Just Drain & Fill?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dkidcat59, Mar 20, 2024.
  1. Mar 20, 2024 at 7:10 PM
    dkidcat59
    dkidcat59 [OP] Member
    2009 Tacoma 4X4 V6
    Got a 2nd Gen 2009 4x4 V6 Tacoma with 170k miles, Bought it used and I've gone 40k with zero problems. It appears the Transmission has never been serviced. The transmission works very well as is.
    Should I take the gamble and drop the Transmission pan and change the filter?
    Or, should I just drain and fill? (keeping about half the old fluid and filter)
    How long can an original filter last?
  2. Mar 20, 2024 at 7:18 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It is not a gamble to replace the ATF filter and do a drain/refill. The gamble is doing a flush. I would get peace of mind dropping the pan to see how it looks in there.
    The filter in our V6 rigs is a metal mesh. Many clean it out with acetone. I replaced mine at 130K. It was only about $30 for a Wix filter.
    Micbt25, 2015WhiteOR and Dm93 like this.
  3. Mar 20, 2024 at 8:11 PM
    TacoTuesday1
    SD CA
    filters are generally not lifetime components.
    drain and fill does not address cleaning potential magnets, getting more fluid out, and renewing the gasket.
  4. Mar 21, 2024 at 6:56 AM
    dkidcat59
    2009 Tacoma 4X4 V6
    Thanks for the info. These answers are a big help.
  5. Mar 21, 2024 at 7:23 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    I dropped the pan, cleaned the magnets & installed a new strainer at 160K! (tranny was never serviced prior and no issues) The magnets had minimal film. I am at 194K and still performing great!!
  6. Mar 21, 2024 at 8:27 AM
    dkidcat59
    2009 Tacoma 4X4 V6
    Great info! I hope for the same results!
    But I'm not sure exactly what you did other than replace the filter.
    Did you drain and fill at each of the intervals in your picture? Or are you saying the new filter cleaned your old fluid?
    I'm assuming you drained fluid, dropped the pan, discarded the old fluid, Cleaned the magnets, replaced the filter and refilled with new fluid.
  7. Mar 21, 2024 at 8:31 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Why is dropping the pan a gamble?
    69 Jim likes this.
  8. Mar 21, 2024 at 9:39 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    The day before I dropped the pan to clean it, the magnets and swap out the screen/filter, I sprayed a little PB Blaster on each pan bolt just to make sure they'd all back out without any issue.
    kwanjangnihm likes this.
  9. Mar 21, 2024 at 11:15 AM
    dkidcat59
    2009 Tacoma 4X4 V6
    I didn't phrase it accurately enough.
    I was trying to say, "Should I dump all the fluid from the pan?" This is because I've heard so many disaster stories about slippage after replacing all the fluid.
    A lot of people say "Just drain and fill." But Chuy above clarified that a flush would be the real gamble.
  10. Mar 21, 2024 at 11:36 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    You’re dumping the majority of the fluid in the pan when you do a drain and fill. There’s probably only about a quart left in the pan after you drain it. With the pan down you’ll probably drain about 4 quarts total and I believe the system holds 12.
    Dm93 likes this.
  11. Mar 21, 2024 at 4:14 PM
    kwanjangnihm
    Jeff
    Central Florida
    same! :thumbsup:
    BlkDakDave[QUOTED] likes this.
  12. Mar 21, 2024 at 4:18 PM
    kwanjangnihm
    Jeff
    Central Florida
    I drained the pan and caught all the transmission fluid as I was removing the pan. (about 4.6.quarts) So after installing the strainer & pan (new gasket), I added 5 quarts of fluid and did the level check. About 1/3 of a quart came out during this process. I performed 2 more drain & fills that were 3 quarts each. Gather the bucket and plastic tub at Lowes.
    BlkDakDave likes this.
