Change transmission fluid or not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ncbowhunter, Mar 23, 2013.
  1. Mar 23, 2013 at 4:42 PM
    ncbowhunter
    ncbowhunter [OP] Member
    02 Double Cab 4wd Tacoma
    First off I'm new to the forum.....thanks for having me!
    I just purchased an 02 Tacoma Double Cab 4wd v6. I got the truck at a good deal and it is excellent cosmetic condition. The lady I purchased it from has changed the timing belt & other maintenance on time with the exception of the transmission fluid (really don't understand why though). The truck has 195k miles and has never had the trans fluid changed. i normally would run the other way, but its a really nice truck. I plan to get the trans fluid changed this Friday at the dealer and get them to add a container of Lucas trans fluid as a precautionary measure. If it was your truck what would you do? Thanks in advance for your help!
  2. Mar 23, 2013 at 4:55 PM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Tough call. Me?....I would leave it. At almost 200k on original fluid, there is a good chance new fluid could cause issues
  3. Mar 23, 2013 at 4:56 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard from the High Desert of Central Oregon! If it was me i'd just do a few drain and fills in a row over the next 1000 miles. I've read complete flushes aren't a good idea at that high of milage.
    Sounds like a nice truck... be sure to share a few pictures. :)
  4. Mar 23, 2013 at 4:56 PM
    Mossy
    billy
    san antonio, TX
    Maybe a drain and refill with new filter. Not sure I'd flush
  5. Mar 23, 2013 at 4:57 PM
    Vidmon88
    Vidmon88 Well-Known Member
    Alex
    San Diego, California
    2021 Off-Road V6
    what mossy said x2 ^ :)
  6. Mar 23, 2013 at 5:41 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Just drain and fill a few times to get the fluid clear.
  7. Mar 23, 2013 at 6:14 PM
    ncbowhunter
    So with the drain and fill.....would you have the dealer do this or do it yourself? What's your thoughts on the Lucas additive? Thanks again.....
  8. Mar 23, 2013 at 6:20 PM
    sirsaechao
    Tim
    CA
    Yep drain and fill it several times until you pull the dip stick and wipe it on a towel it is clear/translucent. All you need is some ATF Dex III/IV.
  9. Mar 23, 2013 at 6:21 PM
    Dando7018
    Dando7018 New Member
    Dando
    NY
    08 Base SR5 4wd
    Changing the fluid is not going to hurt it, and its not going to hurt to add lucus.
  10. Mar 23, 2013 at 8:39 PM
    gearcruncher
    Canadain bumper technician
    I agree with Dando !!
    Newer transmissions use electrical solenoids rather than mechanical shift valves that were used in older automatics .
    There are far less things to go wrong with newer transmissions in comparison to older transmissions . Solenoids dont normally get stuck ...shift valves will stick .
    Flushing all the fluid is highly recomended .
    You are better off replacing the fluid that has lost all the friction modifiers than to worry about sticking some of the mechanical valves in the valve body . Lubeguard should also be used as a supplement .
    http://www.lubegard.com/~/C-113/LUBEGARD+Platinum+Universal+ATF+Protectant
    I would not promote Lubegaurd if it didnt work
  11. Mar 23, 2013 at 11:22 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    I asked same ? few months ago. (135k). Fluid was dark. My dipstick says dexII. I did 2 drain refills and plan on dropping the pan and replacing filter and fill'n it up for good sometime soon. Drains usually about 4qts (book says 2.5 or something).
    Good luck..
  12. Mar 24, 2013 at 6:32 AM
    ncbowhunter
    I have heard nothing but good things about Lubegard....thanks for the info!
  13. Mar 24, 2013 at 6:38 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    where in NC are you ? i can hook you up with amsoil trans fluid at dealer cost
  14. Mar 24, 2013 at 7:11 AM
    ncbowhunter
    Eastern NC.......30 min east of Greenville.....
  15. Mar 24, 2013 at 7:15 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    im origionally from gvagus and my mom still lives there, im headed there this weekend and will be around the Winterville/Grifton area if you want some fluid, heck if you want you can change it in the garage at my moms yourself
  16. Mar 24, 2013 at 7:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd change it, the diffs and transfer case, too.
  17. Mar 24, 2013 at 7:26 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i can get you any amsoil fluid at cost, and can even help you change fluids if you like.
    if interested lemme know so i can get an order in ASAP.
    but as the poster above stated its a good idea to go ahead and change everything, if you like i can even get a blackstone labs oil analysis for ya
  18. Mar 24, 2013 at 8:42 AM
    ncbowhunter
    Thanks for the offer......I am going to check with the dealer on Monday for costs and let you know......Thanks again!
  19. Mar 24, 2013 at 9:40 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    10-4 ill pm you my cell number. It takes about 2 days for stuff to come in
  20. Mar 24, 2013 at 6:00 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Just drain and fill a couple times as there is no filter to change, only a screen. Couple drain and fills and good to go. Get 6 courts of mobile one synthetic 90wt and do rear diff, front diff, and transfer case.
