Change UCAs to install Fox TRD shocks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spynox11, Oct 18, 2021.
  1. Oct 18, 2021 at 2:33 PM
    Spynox11
    Spynox11 [OP] Member
    2019 tacoma trd sport
    Hello, I have 2019 tacoma sport, I want to upgrade my front shocks to fox trd pro, do I need to change the stock upper arm??
  2. Oct 18, 2021 at 2:44 PM
    Ilove2dubb
    Ilove2dubb Well-Known Member
    Jeffrey
    Montreal, Quebec
    2020 Tacoma TRD Sport in Cement
    No. They are the same.
    tcjacado likes this.
  3. Oct 18, 2021 at 2:48 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    No
  4. Oct 18, 2021 at 2:50 PM
    tcjacado
    tcjacado Well-Known Member
    No, you can keep the same uca's
  5. Oct 18, 2021 at 2:51 PM
    Spynox11
    Thank you, what do you think of those fox shocks??
  6. Oct 18, 2021 at 2:51 PM
    mauctopa
    mauctopa Well-Known Member
    But if you get a new shinny billet one you'll get extra mall crawler points :D
    DAS Taco likes this.
  7. Oct 18, 2021 at 2:53 PM
    brandon78lusch
    Brandon
    I have the Fox 2.0 Performance shocks which are a little bit different than the Fox TRD Pro shocks and I think they're great
    bzzr2 likes this.
  8. Oct 18, 2021 at 2:53 PM
    tcjacado
    They are fine, but we have no idea what you are trying to achieve with this upgrade.
  9. Oct 18, 2021 at 3:00 PM
    Spynox11
    My wife saw them on offerup and she told me, I want them
  10. Oct 18, 2021 at 3:05 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I have them on my 2018 offroad long bed. They make the truck much more stable on the highway, it soaks up bumps without issue. Probably one of the best upgrades I have done.
    I recently put in the trd pro lift kit with the suspension (replacement front springs) that lifted me a extra 1.5 inches. Truck feels great!
  11. Oct 18, 2021 at 3:09 PM
    Spynox11
    So the shocks wont lift the truck??? I have the bilstein 5100's that gives you 2 inches
  12. Oct 18, 2021 at 3:14 PM
    tcjacado
    Are you on stock springs with the clip set at 2 or 3 or are do you have aftermarket springs... ome, eibach, toytech?
  13. Oct 18, 2021 at 3:14 PM
    Spynox11
    After market bilstein 5100
  14. Oct 18, 2021 at 3:15 PM
    Spynox11
    Planning on buying fox trd pro
  15. Oct 18, 2021 at 3:16 PM
    .223Taco
    .223Taco Well-Known Member
    Austin, Tx.
    '18 Cement DCSB OR
    The TRD Pro Fox will give an extreme 1" lift
    Spynox11[QUOTED][OP] likes this.
  16. Oct 18, 2021 at 3:18 PM
    tcjacado
    I understand your point, the difference is progressive (fox), vs digressive (bilstien).
    Bilstein will keep your lift, the fox trd pro will not, unless you add spacers. They are a fixed shock, not adjustable.
  17. Oct 18, 2021 at 3:19 PM
    Spynox11
    Ok, whats the best way to add another 1 1/2?
  18. Oct 18, 2021 at 3:20 PM
    tcjacado
    Order the fox 2.0, king, ads.... etc.
  19. Oct 18, 2021 at 3:21 PM
    Spynox11
    On my other truck bought kings with no knowledge and end up buying upper arms and spindle, 5000 dlls total in the front only LOL
  20. Oct 18, 2021 at 3:25 PM
    tcjacado
    Nobody said it was cheap.... you should just ride out the billies and save up for a decent fox suspension that can be adjusted.
    Here I will tag the guru's of suspension here and hope they chime in.
    @AccuTune Offroad
