change when warm??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HDFD10, May 4, 2010.
  1. May 4, 2010 at 5:12 PM
    HDFD10
    HDFD10 [OP] Well-Known Member
    Was going to change plugs right now. Does the block have to be cold when doing this? i have heard it is best to do when cold because of something with the threads?
  2. May 4, 2010 at 5:21 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    I would recommend changing when cold, so you won't burn yourself on any hot object in that area.
    So yes, wait and let it cool down.
    EDIT: This thread is also a good guide through the whole process. http://www.tacomaworld.com/forum/technical-chat/30479-how-spark-plug-change-1-gr-fe.html
  3. May 4, 2010 at 5:23 PM
    HDFD10
    Yes but can i ruin anything like threads changing when warm? Its been about an hour since i got home
  4. May 4, 2010 at 5:26 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    You're totally fine, go ahead and change them. Just make sure to use all the right tools and take your time.
