Changed AC components, light still blinks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trachito, Apr 13, 2022.
  1. Apr 14, 2022 at 7:16 PM
    ThatManitobaGuy
    ThatManitobaGuy Northern Knuckle Buster
    Manitoba
    2015 Magnetic Grey Tacoma SR5 4X4
    265/75R16 Goodyear Wranger Duratrac tires TRD Off Road Skid Plate iDatastart Remote Starter
    Did you check the continuity of the wires going to the compressor? A relay can work fine but if you have high resistance or an open in the harness it won't matter. Seeing that you replaced the compressor assembly already won't ask about the ground on the coil.
  2. Apr 15, 2022 at 7:28 AM
    Trachito
    Trachito [OP] Well-Known Member
    New Orleans
    You guys are gonna help me make this truck last forever, lol
  3. Apr 15, 2022 at 7:30 AM
    Trachito
    New Orleans
    I did not. If the amplifier doesn't work, I'll move onto wiring. Tracing shorts in wiring is something I hate doing. I just never got that proficient at it.
  4. Apr 26, 2022 at 7:32 AM
    Trachito
    New Orleans
    It was the amplifier, Toyota part 88650-04030. It's located behind the glove box, upwards and towards the center of the open area behind the glove box. I had to unbolt the ECU bracket to access the bolt that holds the amplifier, then I used a small 10mm ratcheting wrench to get the bolt off. Bit of a pain to squeeze my hand up there.
    Rob MacRuger likes this.
