Changed anti-Freeze, now heater is not working, Help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hunt/Taco, Oct 7, 2019.
  1. Oct 7, 2019 at 4:38 PM
    Hunt/Taco
    Hunt/Taco [OP] Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    Drained the radiator/ motor block of anti-freeze (2.7L). Filled radiator took about 1.8 gallons. Started it up with heat on full blast and added some when running motor up on ramps (raised front of truck), until there was no air coming out. There is no heat coming out of the vents at all, it is cold air. Also big top hose from radiator to motor is warm/ hot, where as the big radiator hose from bottom of radiator to motor is cold. Also the hoses into the cab for heat are cold also. I ran the truck for 15 mins idling, and temp gauge showed 1/2 way for temp (where it is always at). I am stumped right now. Help!!
  2. Oct 7, 2019 at 4:42 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Sounds like air, burp the system.
    95 taco and Hunt/Taco[OP] like this.
  3. Oct 7, 2019 at 4:43 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Put the truck back on level ground.
    See if you can add more coolant.
    Start the motor like before till thermostat opens. Fill radiator more if I'll take it.
    Put radiator cap on. Fill overfliw tank to normal level. Then let it sit overnight.
    It may suck in more coolant and should be good to go.
    GQ7227 and Hunt/Taco[OP] like this.
  4. Oct 7, 2019 at 4:54 PM
    Hunt/Taco
    Coleman
    Yep I just went out, before I saw your guys comments, started truck (still on ramps), and the level went way way down this time, filled it up again, no more bubbles, and boom piles of heat now! Thanks for the quick responses guys!! I was getting a little freaked out. So I guess what did it, was to run the truck for 15 mins, then let it cool about 30-40 mins, start it back up, and add more coolant. Must have leaked more anti-freeze in the system/ get the air out when it was sitting for 30 mins!! Either way problem fixed!
    cruisedon66[QUOTED] and GQ7227 like this.
  5. Oct 7, 2019 at 4:55 PM
    Brianz1001
    Brian
    too much to type
    That’s good OP, but always fill fluids on vehicle on flat level ground.
    Hunt/Taco[QUOTED][OP] likes this.
  6. Oct 7, 2019 at 5:05 PM
    Hunt/Taco
    Coleman
    I did fill it at first on the flat garage. Once it was topped off, I started truck, drove up on ramps (front end) to burp system, and add anti-freeze when needed. That is how all the guys where doing it. Either way my truck is back boys!! Going to let her sit all night long, and check fluid level in morning.
