Changed Caliper, Now Steer/Ignition Locked
Discussion in '4Runners' started by GambleMan, Aug 20, 2017.
  1. Aug 20, 2017 at 5:18 PM
    GambleMan
    GambleMan [OP] Member
    Travis
    Toyota 4Runner
    So yah, I changed out my Caliper on my 4runner '90, and now my steering is locked and ignition is locked. This has happened before, but never this bad before. It will not rattle lose at all.
    Any ideas?
  2. Aug 20, 2017 at 5:42 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I get a call from my wife or my mother in law at least once a year for this.
    I tell them to grip the wheel and yank it one way and try to turn the key. If that doesn't work, grip it and turn it the other way. Works like a charm.
    Oreo Cat and outlawtacoma like this.
  3. Aug 20, 2017 at 5:43 PM
    GambleMan
    Travis
    Toyota 4Runner
    Tried so many times! like i said, it's happened before, but never like this. Any clues?
  4. Aug 20, 2017 at 5:44 PM
    Justinlhc
    WD40 in the keyhole?:notsure:
  5. Aug 20, 2017 at 5:49 PM
    Tacoma Mike
    Southern Maine
    Moving the steering wheel to take the pressure off the lock pin while trying to turn the ign and it won't release is what your saying.
    Anytime This happens to a cust the first thing I suggest is getting a new key made. Not copied from your old one. A new cut by vin at the dealer.
    Take your reg and drivers license and get a cheap non chip key made by vin. Then go try it.
    Quite often this is the cure. Not all the time but a cheap key is a lot better to try than replacing a ign lock cyl etc for nothing. I'm not there to feel if there are any other issues but that's where I would start.
  6. Aug 20, 2017 at 6:00 PM
    GambleMan
    Travis
    Toyota 4Runner
    I guess i may have to get a factory key made. I find it odd how they don't even let you turn they key to be able to pull the ignition lock out. I will have to get a cut for the vin on my other truck, because that part was pulled from my '95 Runner.
  7. Aug 20, 2017 at 6:02 PM
    GambleMan
    Travis
    Toyota 4Runner
    Any other ideas would be appreciated!
  8. Aug 20, 2017 at 6:06 PM
    Tacoma Mike
    Southern Maine
    Yea you are correct... Ask them to write the code for you. Save it for future reference.
  9. Aug 20, 2017 at 6:07 PM
    Bishop84
    Bishop84 Well-Known Member
    Is the steering fully locked to one side? You may have to seperate your pitman arm, it's the ball joint that connects the steering gear to the drag link. Remove the cotter pin, remove nut, smash drag link with hammer, free up steering tension.
  10. Aug 20, 2017 at 6:20 PM
    GambleMan
    Travis
    Toyota 4Runner
    Ouch. That sounds like a chore. I would have no idea what i'm doing there. Would taking off a tire and changing the brakes cause that issue?
  11. Aug 20, 2017 at 6:29 PM
    Tacoma Mike
    Southern Maine
    There's enough play you can flex the system to release the lock pin.
  12. Aug 20, 2017 at 6:42 PM
    GambleMan
    Travis
    Toyota 4Runner
    I can't turn it left or right, it's locked both ways. Key won't budge, tires won't budge. I don't know how to flex the system and release a pin. I'm lost in that area. :(
  13. Aug 20, 2017 at 6:46 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Mine used to do this occasionally. It finally did it at work in my 2002 tacoma. Tried everything.
    Had the truck towed home, grabbed an extra original key that I never used and it started right up.
    The key is probably worn down so bad that it wont engage the tumblers.
  14. Aug 20, 2017 at 6:57 PM
    Tacoma Mike
    Southern Maine
    Get a key and start there. Eliminate the easy stuff before you pull your hair out.
  15. Aug 20, 2017 at 7:13 PM
    GambleMan
    Travis
    Toyota 4Runner
    What blows my mind is it worked before I changed my caliper. I tried my spare key, it didn't work either. Going to try a new original copy tomorrow i guess.
    Matic[QUOTED] likes this.
  16. Aug 20, 2017 at 8:01 PM
    Matic
    Tricky Dick
    Easley, SC
    That is wierd.
    I bought my truck new in late 2001 and always used the plain spare key, never the original black key. After 13 yrs it just finally wore down.
    I dont know of anything that could have happened when you changed the calioer out that would have affected the wheel lock or tumbler.
  17. Aug 20, 2017 at 8:39 PM
    GambleMan
    Travis
    Toyota 4Runner
    I don't either, that's what is making my head spin. I am going to try the locksmith tomorrow, and then the dealership if that doesn't work out.
  18. Aug 21, 2017 at 12:15 PM
    GambleMan
    Travis
    Toyota 4Runner
    New key cut worked! Barely. They didn't have the proper Toyota keys either, just the cheap ones. But it still got a clean factory cut. Probably need new Ignition switch again then.
    Justinlhc and Tacoma Mike like this.
