Changed engine oil and it now smokes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jerome1877, Jan 14, 2013.
  1. Jan 14, 2013 at 9:42 AM
    Jerome1877
    Jerome1877 [OP] Member
    Jay
    Sxm Netherlands Antilles
    Hi,
    I have a 1995 tacoma 3.4 l,this morning I changed the engine oil and filter,I used 5 sae 30, and when I started she was smoking ,on the previous oil changed I used 10 sae 30 and their was no smoke,I purchased the truck in October ,214000 miles on her now,
    Should I change the oil for the 10 sae 30.
    I am in the tropics,
    Pls advice
    Jay
  2. Jan 14, 2013 at 9:47 AM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/Washington
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    make sure your filter is on straight. it happened to me once before, and the little bit that leaked out was burning up and caused some smoke to come outa da hood.
  3. Jan 14, 2013 at 9:51 AM
    ruggedT
    ruggedT The Sticker Guy Vendor
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    You positive you drained the engine oil? Not the trans
  4. Jan 14, 2013 at 9:57 AM
    Jerome1877
    Jay
    I meant it comes out of the exhaust pipe,it hardly use too before.
  5. Jan 14, 2013 at 9:58 AM
    Jerome1877
    Jay
  6. Jan 14, 2013 at 10:01 AM
    SteveT
    SteveT Well-Known Member
    Clarksville TN
    4x4/TRD
    what color is the smoke? white/gray is coolant in the oil, black is rich fuel, blue/gray color means oil in combustion chamber
  7. Jan 14, 2013 at 10:02 AM
    Jerome1877
    Jay
    White / gray.
  8. Jan 14, 2013 at 10:02 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    It is now a diesel.. Fappity fap fap...
  9. Jan 14, 2013 at 10:03 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    With that many miles, and being in the tropics, I see no reason to not use 10w-30 since you're burning 5w. I'd just run a high mileage conventional
  10. Jan 14, 2013 at 10:03 AM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Do you have a compression tester?
  11. Jan 14, 2013 at 10:20 AM
    Jerome1877
    Jay
    Changing the oil now for 10 /30 hope it will solve the smoke issue!
  12. Jan 14, 2013 at 10:21 AM
    Jerome1877
    Jay
    No I don't .
  13. Jan 14, 2013 at 10:50 AM
    Jerome1877
    Jay
    So changed the oil with 10 /30 no white smoke when I started the engine
