Changed head gasket....truck won't start...please help
Discussion in '4 Cylinder' started by VLANDER005, Dec 18, 2009.
  1. Dec 18, 2009 at 4:03 PM
    VLANDER005
    VLANDER005 [OP] Well-Known Member
    96 YODA, 2.7 I4, 31" MTR's
    31" Goodyear MTR's
    I have 130k on my yoda and just replaced the head gasket. It is a 2.7 I4 5 speed. I have everything put back together and the truck will not start. I have good spark, and I am getting plenty of fuel. The timing should be right on because the distributor is pointing towards the #1 cyl spark plug with the #1 cyl at TDC. Please help. The truck is flooded now so I have to wait for it to dry up. I didn't have the firing order correct at first because autozone had the rotation of the distributor backwards. Please help. I am open to any ideas!!!
  2. Dec 18, 2009 at 4:06 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It should point a little before the #1 position when at TDC.
    Does it sound like it's firing? sputtering at all?
  3. Dec 18, 2009 at 4:13 PM
    VLANDER005
    31" Goodyear MTR's
    No...not even a sputter. If I move the distributor forward or back one tooth it doesn't point at number 1 cyl.
  4. Dec 18, 2009 at 4:27 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Does it look like this?
  5. Dec 18, 2009 at 4:37 PM
    VLANDER005
    31" Goodyear MTR's
    Just like that. I have the same manual and it has been worth its weight in gold. Actually, I downloaded it offline in a pdf format.
  6. Dec 18, 2009 at 4:44 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That's where I got it. :thumbsup:
    Just covering all the bases here so don't take offense to any of the questions:
    You are on the timing mark?
    Cam was installed correctly?
    Firing order is correct?
  7. Dec 18, 2009 at 4:49 PM
    VLANDER005
    31" Goodyear MTR's
    No...I appreciate any help I can get because I am completly out of ideas.
    Firing order is correct according to the pdf document.
    Cyl #1 at TDC is pointing just like the manual.
    Spark is good on all 4 cylinders.
    Plugs are brand new, wires, cap rotor, fuel filter, all done in july
    checked the resistance on coil, according to the pdf file, primary coil resistance was a bit high at .6-.7 ohms instead of .36-.55
    Cams are correct, I pulled the plug on cyl#1 and put the wire back in the chamber to verify TDC on compression stoke..it was defintly on compression stroke.
  8. Dec 18, 2009 at 4:51 PM
    VLANDER005
    31" Goodyear MTR's
    The only idea I have left is that it is flooded and wont' start because of that. Again..I had the firing order wrong because of the autozone website. They had the dist rotating clockwise instead of cc. So, it flooded the cylinders with fuel. So..i'm guessing that it won't 'start because of excess fuel in the cyl. I have all plugs out letting the fuel dry up.
  9. Dec 18, 2009 at 5:01 PM
    VLANDER005
    31" Goodyear MTR's
    I also rolled the engine over by hand to verify no interference with the cylinders and valves.
  10. Dec 18, 2009 at 5:15 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It sounds like it should fire. Take your plugs out and let it sit for an hour or so. Then try it again.
  11. Dec 18, 2009 at 5:24 PM
    VLANDER005
    31" Goodyear MTR's
    That is the plan for now. It has been sitting for 1.5 hours so I'll go out and look in the cylinders to see if I can see fuel. I'll go out now and let you know.
  12. Dec 18, 2009 at 5:25 PM
    VLANDER005
    31" Goodyear MTR's
    Cyl#1 looked fairly dry compared to earlier. I am going to give it another hour just incase and give it another try. I appreicate the help.
  13. Dec 18, 2009 at 5:41 PM
    VLANDER005
    31" Goodyear MTR's
    I just tried again without any luck. The truck isn't even trying to start.
    What else could contribute to the truck not starting?
    Too much fuel or fuel pressure?
    Plug not being the correct cold or hot level?
    What sets the fuel injector timing?
    Would the reading on the coil primary resistance be too high as not to allow a strong enough spark? What else can I check?
  14. Dec 18, 2009 at 6:26 PM
    VLANDER005
    31" Goodyear MTR's
    I just double checked the vaccum connections on the throttle body and everything matches the manual.
  15. Dec 19, 2009 at 5:07 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The crank sensor. Is it hooked up?
  16. Dec 19, 2009 at 5:59 AM
    VLANDER005
    31" Goodyear MTR's
    It is hooked up. Would that cause it not to start if I'm getting spark?
  17. Dec 19, 2009 at 6:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Not necessarily. If your timing is good, you have spark and fuel, the only thing left to check is the compression. If you have all four of those, it should fire.
  18. Dec 19, 2009 at 6:07 AM
    VLANDER005
    31" Goodyear MTR's
    Is it possible that I installed the cams incorrectly? Could the spark be too weak to burn the fuel? My ignition coil measures .6 on the primary. According to the pdf manual it should read between .36-.55 ohms while cold. Could that .06 ohms really make it weak enough not to run? What should the compression read?
  19. Dec 19, 2009 at 6:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The compression should be 120 psi or better. Yes it is possible to have the cams installed incorrectly. It is a non-interference engine so no damage would occur. Check your compression on each cylinder and we can go from there.
  20. Dec 19, 2009 at 6:27 AM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    Did you verify TDC with a compression guage? It sounds to me that you might be at the top of the exhaust stroke. Something to check.
