Changed manual tranny fluid...went badly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Dec 3, 2017.
  1. Dec 3, 2017 at 6:50 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    So I decided to change tranny fluid. I prepared well, got the fluid, the socket, the fluid pump. Cracked the fill bolt, drained the fluid. (Seemed like less than 2 quarts came out but it had to have drained properly)
    Replaced the drain plug, then started to fill the tranny. Here's where I ran into trouble. The pump was defective, fluid started leaking out the top of the pump. PIECE OF SHIZZZ. Now, this is 3 pm on Sunday. Nothings open that carries a fluid pump that I need. Here I am trying to jimmy the pump because I am SOL if I don't get the fluid back in.
    So I dump out my kids suave shampoo, rinse our the shampoo and use that. Luckily it worked. BUT, have you ever tried to pump 2 quarts of fluid through a shampoo bottle? Took forever. Forever. Anyway a 30 minute job turned into a 2+ hour job. All because of a stupid defective pump.
    Anyway the redline fluid is NIGHT AND DAY. It feels so much smoother. Like butter is in there. Holy smokes.
    PzTank, Shark18, toucan and 2 others like this.
  2. Dec 3, 2017 at 9:01 PM
    HansLanda
    HansLanda Well-Known Member
    Nice, glad you got it working!
    Just flushed my automatic tranny with Toyota WS, and immediately the 2nd to 1st downshift felt smoother.
    I also know how you feel about the pump. Mine did not break, but I ordered the wrong size. The screw top was meant for a differential fluid bottle, which is not large enough for the tranny fluid bottle. Still made it work, but had to hold them together.
