Changed my spark plugs, weird light on dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scout27217, Apr 15, 2013.
  1. Apr 15, 2013 at 7:25 AM
    scout27217
    scout27217 [OP] Member
    Aaron
    Mocksville, NC
    2016 Barcelona Red SR5 4WD DCSB
    Has anyone seen this indicator before? It is right below the Check Engine light.
  2. Apr 15, 2013 at 7:26 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
  3. Apr 15, 2013 at 7:26 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Abs traction control. Switch somewhere?
  4. Apr 15, 2013 at 7:29 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    ya thats your traction control, so if you have it in park and shut off the egnine, then re-start the engine does it come back on?
  5. Apr 15, 2013 at 7:39 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Mine did the same thing after a plug change. Make sure all the coil packs are snapped in. Disconnect the battery for a few minutes then connect it back and start it. The light should go out.
  6. Apr 15, 2013 at 8:25 AM
    scout27217
    Aaron
    Mocksville, NC
    I'll do that after I check the code with my scanner at work.
  7. Apr 15, 2013 at 8:37 AM
    BamaToy1997
    Bill
    Navarre, FL
    Top light is check engine light, bottom light is traction fault light.
  8. Apr 28, 2013 at 5:54 PM
    scout27217
    Aaron
    Mocksville, NC
    When I cleared the light it never came back. I guess
  9. Apr 28, 2013 at 5:55 PM
    scout27217
    Aaron
    Mocksville, NC
    Stupid mobile. I was trying to say that I guess the lights came on because I had disconnected so many sensors without disconnecting the battery.
  10. Apr 28, 2013 at 6:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Check engine light frequently commands a VSC light as well.
    Likewise ABS will typically trigger VSC.
  11. Apr 28, 2013 at 9:48 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    aside from checking/ changing fluids, disconnect negative battery cable ANYTIME the hood is up. its just good practice.
