Changed oil: Startup=loud top end "ratchet"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecoterragaia, Feb 27, 2011.
  1. Feb 27, 2011 at 12:50 PM
    ecoterragaia
    ecoterragaia [OP] Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    I just changed my oil for the 2nd time today. When I started it up to circulate the oil, there was an awful "ratcheting" sound that came from the top end. It only lasted for a split second. I assume that this was caused by the oil being pumped to the hydraulic lifters, but it didn't happen the first time I changed the oil. Also, the engine typically revs to 2000 rpms when you first start it, and this time was no different.
    Could this have caused any damage? Has anyone else had this happen?
    Thanks
  2. Feb 27, 2011 at 12:52 PM
    DevL
    DevL Well-Known Member
    Thats the sound it makes if you drain all the oil and its not lubed. Noise stops when the oil gets pumped through the system. I would not sweat it as far as damage.
  3. Feb 27, 2011 at 1:03 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That is normal. I work at an auto shop and some vehicles are worse for this than others. But nothing to worry about. There were a couple of times that I actually shut the engine down quickly and double checked that I had added oil cause the noise was so bad.:eek: Of course everything was ok, but still scared me.
  4. Feb 27, 2011 at 1:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    There are no Hydrolic lifters on teh Tacoma engines.
  5. Feb 27, 2011 at 1:37 PM
    NelsonTacoma
    Tucson, AZ
    :rofl:
    I laugh everytime I read your posts. At least you are consistent.
  6. Feb 27, 2011 at 1:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No time for speel check :p
  7. Feb 27, 2011 at 2:09 PM
    ecoterragaia
    Mid-Atlantic
    Sorry, shouldve said lash adjusters. My main question was whether or not the lack of oil pressure would cause any damage? Sorry for the confusion.
  8. Feb 27, 2011 at 3:46 PM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    The oil filter isn't mounted upside down, but on other trucks like the Chevy the oil filters are mounted upside down so you can fill up the new oil filter with the new oil before installing it and when you start it up you don't have to wait for the oil pump to fill up the oil filter cause its already filled and WAAA-LA instant oil pressure!
    It takes time for the oil pump to fill up and circulate thru the oil filter!
    I TOLD you guys about using the PROPER oil filter, but NOOOOOOO don't listen to me!
  9. Feb 27, 2011 at 4:07 PM
    ecoterragaia
    Mid-Atlantic
    I'll have to keep that in mind, filling the filter before attaching it. BTW, I only use the Toyota oil filters on this truck, which brand SHOULD be used?
  10. Feb 27, 2011 at 4:12 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    In all the dissections, Toyota filters were shown to have the largest surface area. It may in fact be better than the TRD filter (the one with a welded nut on top).
