Changed plugs today at 60k.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lthompson, Dec 18, 2016.
  1. Dec 30, 2016 at 2:38 PM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have problems with cat's etc and they find that the plugs have not been changed they will not honor the warranty.
  2. Dec 30, 2016 at 2:40 PM
    #42
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    That more than likely is why the coil pack went south.
  3. Jan 12, 2017 at 12:33 AM
    #43
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Do you have a part number? It keeps pulling these up for me, just wanting to make sure these are the copper ones for the 4.0 and not the Iridium 2.7 plugs
    1Shifter[QUOTED] likes this.
  4. Jan 12, 2017 at 1:09 AM
    #44
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
  5. Jan 12, 2017 at 8:53 AM
    #45
    4x4Taco09
    Dane
    Louisiana
  6. Jan 12, 2017 at 9:02 AM
    #46
    1Shifter
    Jeff
    09 PreRunner
    Good luck!
  7. Jan 12, 2017 at 9:06 AM
    #47
    4x4Taco09
    Dane
    Louisiana
    Oh I changed mine back at 60k or 70k. They shouldn't be hard taking out. I didn't wait too long, luckily lol
  8. Jan 12, 2017 at 9:42 AM
    #48
    spanke311
    spanke311 Well-Known Member
    Santa Cruz
    05 TRD 4x4 V6 6spd
    I changed my plugs when I bought my truck around 80k miles. Found the mixed denso/nkg, and the plugs on the driver's side were worn considerably more the the passenger side (I can't remember for sure, but I think Denso was on the driver's side). I had just figured previous owner went to change plugs and got lazy on the driver's side because they're more difficult to get out.
  9. Jan 13, 2017 at 7:52 AM
    #49
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Just got my 30,000 mile service done at the dealer. I know i know, everyone hates the dealerships and blah blah blah. My toyota dealership actually has some very good seasoned technicians. Just let them do it, plus its all done by dealership work so shouldnt have any warranty issues. I got a new air filter, cabin air filter, tire rotation, oil change, new spark plugs, retorqued everything that was supposed to be torqued and it cost just at 200 bucks. I dont think thats to bad considering it was all factory items and done by dealership labor.
    willee51 likes this.
  10. Jan 13, 2017 at 8:06 AM
    #50
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    $200 bucks for all that. Not bad honestly.
  11. Jan 13, 2017 at 8:39 AM
    #51
    Pigpen
    Dan
    Northwest Montana
    Too bad they didn't change fluid in the diffs, t case (and tranny, if a manual), as Toyota suggests for 30K mile maint. Did they even grease the drive shaft??
  12. Jan 13, 2017 at 10:51 AM
    #52
    TacomaMike37
    13' DCLB MGM
    Too bad...
    None of that is even recommended at 30K under normal operating conditions (except for drive shaft).
  13. Jan 13, 2017 at 11:18 AM
    #53
    4x4Taco09
    Dane
    Louisiana
    Just put in my Denso Copper plugs, man I forgot how much of a pita the coil pack on I think #1 is (first in the left bank) WOW.
    I had put in NGK Iridium around 35-40k ago, they looked like that were on their last leg
  14. Jan 13, 2017 at 11:42 AM
    #54
    ecotecin
    WV
    Ill have to look on my list of things they done. And i will get back to you on that.
    The more you go to my dealer, it seems they treat you a little better. Originally at another dealer they were charging closer to $260 for the exact same stuff my dealer done for 200. But i have had all my oil changes and everything done at my dealer. I called another dealer because we were going to be out of town when the 30,000 mile mark was going to hit, and im kind of OCD about getting as close as possible. But the trip got rescheduled so i done it with my regular dealer. Which i probably would have waited anyways because of fear of a different dealer.
  15. Jan 17, 2017 at 6:36 PM
    #55
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    why are they using standard plugs and not iridium once? in manual it says only one engine uses iridium tipped plugs. is it not recommended to use better plugs or what
  16. Jan 17, 2017 at 6:53 PM
    #56
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    That's one of the reasons I switched to a Volant intake and only take air from the snorkel.
    Because the wheel well kicks up too much dirt and gets sucked into the filter.
    I have a off road filter and an on road filter and my on road filter looks terrible after just a year.
  17. Jan 17, 2017 at 6:55 PM
    #57
    shr133
    Muskego, WI
    2010 V6 Sport
    I switched to iridium plugs.
    Even in Toyota sales training they where claiming to use iridium plugs.
  18. Jan 17, 2017 at 7:08 PM
    #58
    sy272004
    West Chester
    15 TRD V6 4x4 DC
    i guess ill ask them tomorrow if its ok to do irridium
  19. Jan 17, 2017 at 7:46 PM
    #59
    shr133
    Muskego, WI
    2010 V6 Sport
  20. Jan 17, 2017 at 7:54 PM
    #60
    sy272004
    West Chester
    15 TRD V6 4x4 DC
    I think that's more couse iridium have less top arear so spark is in same place. If regular once had tip in same shape it would probably been same kinda spark. That material probably can't take heat like iridium can
    shr133 likes this.
