Changed plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Dec 9, 2019.
  1. Dec 9, 2019 at 2:47 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Which ones?
    Hendrix834 likes this.
  2. Dec 9, 2019 at 2:48 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Either the ngk or the denso.... Matters not, they're inexpensive, they work and they're what the OEM calls for.
    Lester Lugnut likes this.
  3. Dec 9, 2019 at 2:52 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I would stick with what Toyota designed the truck for....
  4. Dec 10, 2019 at 7:01 AM
    Gearheadesw
    Davenport Fl
    What is it you guys don't get? They come with two, 2, separate brands of plugs from the factory. And yet we still have, what the manufacturer suggests....
    God I'm glad I'm old and think.
    HONY BADGER likes this.
  5. Dec 10, 2019 at 7:02 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Why would they use different plugs on each side? If that is fine by you, would you be okay with Goodyears on the drivers side and BF Goodrich on the passenger of your new truck? Makes no sense.
  6. Dec 10, 2019 at 7:24 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    gap and re use
    here are mine after 210k miles
    https://www.tacomaworld.com/threads/first-plug-change-at-210k-miles.604574/
  7. Dec 10, 2019 at 8:50 PM
    Gearheadesw
    Davenport Fl
    I give up.....:bananadead:
    JC15Taco, PzTank and Jimmyh like this.
  8. Dec 11, 2019 at 3:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Did you give up on Toyota? Just noticed you drive a GMC :rolleyes:
  9. Dec 11, 2019 at 4:01 AM
    Gearheadesw
    Davenport Fl
    I did. They don’t make a truck for me at this point in my driving career. I like being able to haul my thousand pounds of tools, and still be able to throw the thousand pound 4 wheeler in the bed for the weekend. Just easier then the trailer gig I was doing.
    PzTank and six5crèéd like this.
  10. Dec 11, 2019 at 4:05 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I get it, I have a GMC 2500HD as well, the Toyota gets driven way more though :thumbsup:
    Gearheadesw[QUOTED] likes this.
  11. Dec 11, 2019 at 9:03 AM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    for those who have swapped out for all densos- do they come pre gapped for the 4.0?
  12. Dec 11, 2019 at 9:07 AM
    IL Capo
    Sidney BC Canada
    I replaced mine with Denso but did check them all to make sure they were gaped correctly...other than a small correction of one plug they were ready to go (install).
    cromag27 likes this.
  13. Dec 11, 2019 at 9:40 AM
    12retire
    12retire [OP] •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    That’s weird, when I checked my gaps there was one that was a little off also.
    Hmmm
  14. Dec 11, 2019 at 10:30 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    I always check the gaps prior to install. Even *if* they might be pre-gapped, anything can happen between the factory and your driveway. Even with the little cardboard protective tubes. Trust but verify....
    Blockhead, cromag27 and six5crèéd like this.
  15. Dec 11, 2019 at 2:42 PM
    #35
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Yes indeed...ALWAYS check the gap, only takes a second.
    XSplicer62[QUOTED] likes this.
  16. Dec 11, 2019 at 6:24 PM
    #36
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I respectfully disagree. Plugs should always be examined every 15K, cleaned, check gap, and put back in. Should be replaced every 30k in my personal opinion, considering how important they are to MPG's and overall performance. But to each their own.
    JC15Taco likes this.
  17. Dec 11, 2019 at 6:28 PM
    #37
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    I agree, but I would submit, that a pull, clean and gap at 30 k...Might be sufficient... I'd dump them at 60k though.
    Should add...just changed out mine at 32 k...old plugs looked good though...
  18. Dec 11, 2019 at 6:50 PM
    #38
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    A friend of mine had brand new NGK’s put in his 98 Toyota, about 4 months later one of the tips came off and beat up the inside. The mechanic that put them in had to pull the head and fix it. Talked to NGK and they said they were out of warranty and it cost my buddy about $1,600 in repairs.
  19. Dec 11, 2019 at 6:53 PM
    #39
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Sometimes, shit just happens...
  20. Dec 11, 2019 at 9:15 PM
    #40
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    nah
