Changed plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Dec 9, 2019.
  1. Dec 12, 2019 at 3:07 AM
    #41
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Iridiums change around 80000-100000 miles. Regular plugs I would change about 60000 and put the Iridium in. No need to overthink about plugs.
  2. Dec 12, 2019 at 3:45 AM
    #42
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I’m puzzled when people do this. If you’re going to all that trouble why not just spend the $25 for new plugs instead of putting the old ones back in? But, like others said, to each his own...
    mikalcarbine and six5crèéd like this.
  3. Dec 12, 2019 at 4:13 AM
    #43
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I agree, that's like changing the air in your tires from winter to summer. If the thing is running good, why clean the plugs or even check them every 15K?
    Blockhead[QUOTED] likes this.
  4. Dec 12, 2019 at 3:31 PM
    #44
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Carbon deposits.
  5. Dec 15, 2019 at 5:16 PM
    #45
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    I guess at 130k i should take a look at the plugs now huh...
    What are the part numbers for stock replacements? NGK and Denso
    I used to just run NGK TR6's when i put nitrous through my old silverado and TR55's on motor tunes... No clue what these little 6 cylinders use
  6. Dec 15, 2019 at 6:56 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    k20hr-u11 (Denso)
    TxStVanWilder[QUOTED] likes this.
  7. Dec 17, 2019 at 10:59 AM
    #47
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Why check oil level? Why change the oil and oil filter? It's still good right? Check the blinker fluid level, absolutely! These are machines, parts need to be checked, things need maintenance.
    six5crèéd[QUOTED] likes this.
  8. Dec 17, 2019 at 11:07 AM
    #48
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Ain't nobody got time to check all that mess. When mine stops leaking oil on the cement I know it needs some more. It sweats horsepower.
    Green Jeans likes this.
