changed rear diff oil at 11k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdSurgie, Mar 4, 2012.
  1. Mar 4, 2012 at 12:40 PM
    TrdSurgie
    TrdSurgie [OP] revised
    Oahu
    I changed my rear diff oil at 11k yesterday. Super glad I did. The oil had a weird metalic sheen to it. Also the drain plug had a few metal slivers on it. I know this is normal. Just saying so maybe it will motivate some others to change their (brake in) oil sooner than 30k.
    I used 85-140 Lucas gear oil as recommanded by East Coast Gear Supply.
    I didn't bother with taking pics.
  2. Mar 4, 2012 at 12:51 PM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
    Normal at any mileage.
  3. Mar 4, 2012 at 12:54 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    just curious...why didn't you go with the weight Toyota recommends?
  4. Mar 4, 2012 at 12:57 PM
    TrdSurgie
    Oahu
    The heavier weight will prolong life. However there will be a slight affect on mpg.
  5. Mar 4, 2012 at 2:23 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Hmmm. I do not think it will hurt anything, but 85W140 should hammer your mileage.
    I have over 250k on 75W85, which is what Toyota recommends. How long do you want it to last?
  6. Mar 4, 2012 at 2:26 PM
    TrdSurgie
    Oahu
    FOREVER! lol Ill keep track of my mileage for a couple of tanks. If its considerably bad ill change it out again.
    Thanks for the info!
  7. Mar 4, 2012 at 2:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    85w140 is only going to "prolong life" if you do a LOT of heavy towing in hot weather.
    For normal driving with little or no towing, or only towing a couple of quads, stick with 75w90.
    You're better off simply changing more often than going with the heavy oil.
  8. Mar 4, 2012 at 2:47 PM
    TrdSurgie
    Oahu
    I see. Thanks
  9. Mar 4, 2012 at 2:50 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    :confused:
    What next, 20W50 in the engine.
  10. Mar 4, 2012 at 2:52 PM
    TrdSurgie
    Oahu
    Hey:jerkoff: its not like i came up with this on my own. Others on this forum use it and ECGS recommeds it.
  11. Mar 4, 2012 at 2:56 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Use what the manual says
  12. Mar 4, 2012 at 3:45 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I also use Lucas 85-140 in both my front and rear diff and my transfer case as well. I switched over from Mobil1 synthetic after numerous conversations with Chase from East Coast Gears. Also other specialist have also stated that in thier opinion this is the best diff and transfer case oil.
  13. Mar 4, 2012 at 4:55 PM
    TrdSurgie
    Oahu
    Any unwanted affects?
    ECGS said they are right next to a Toyota dealership and they do all of the axel rebuilds for them.
  14. Mar 4, 2012 at 4:57 PM
    jandrews
    '09 FourDubDee TRD OR
    85-140 is good insurance in these trucks for "hard use". I'll be switching to it once I regear.
  15. Mar 4, 2012 at 4:59 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    LOL! :D
  16. Mar 5, 2012 at 1:28 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    no unwanted affects at all. everything works as smooth as butter even in single digit temperatures,
  17. Mar 5, 2012 at 11:04 AM
    TrdSurgie
    Oahu
    Thats great. Thanks for the good information. Just because the manual says something doesnt mean its best.
  18. Mar 5, 2012 at 2:30 PM
    jandrews
    Depends on what you define as "best". 75-90 is best for mileage. However, if I wheel my truck hard and break the diff, mileage don't come into play, so in that case "best" is maximum protection for the gears.
  19. Mar 5, 2012 at 3:43 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    This^^^:cool:
  20. Mar 5, 2012 at 3:46 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    That's what it should of looked like ;)
