Changed rear exterior door handle - now door won’t open
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Minou87, Mar 8, 2024.
  1. Mar 8, 2024 at 3:42 PM
    Minou87
    Minou87 [OP] New Member
    Cat
    2023 White Tacoma Off-Road (Full 4-Door)
    TRD Pro Grille Falken Wildpeaks Replika Wheels Satin Black
    Hi everyone,
    Quick question: I successfully removed my door panel, unscrewed the lock cylinder to slide it down to access the torx screw for the end-piece of the exterior door handle (along with the torx screw for the other end of the handle), and swapped handles.
    I returned the lock cylinder to its correct position, screwed it back in place- but now when I pull open the exterior handle, it doesn’t pull the actual cable to open the door.
    I can see a blue plastic lever move (inside the door), and can feel the exterior handle moving the mechanism in the door, but it’s as though the mechanism isn’t connecting to the lock cylinder.
    I can pull the actual cable (the one that connects to the interior handle) and feel the interior mechanism moving on the “inside” handle/door lock side, but there is no connection to the mechanism for the exterior handle… what am I missing?
    i hope I am explaining myself clearly… I basically reassembled everything step by step, but pulling the exterior door handle does nothing. I’ve tried to find a microfiche of image of the correct assembly to see what isn’t “connecting” but haven’t been successful.
    It is my rear driver’s side door handle.
    Any help would be greatly appreciated!
    TIA
  2. Mar 8, 2024 at 3:50 PM
    Toyko Joe
    Toyko Joe Here for the pictures
  3. Mar 8, 2024 at 3:54 PM
    joel1952
    joel1952 Member
    I've worked on my door latches, locks and linkage about 5 times. So many little things to go wrong
    You are going to have to look closely at the linkage and handles with a strong light.
    Was the new door handle exactly like the old?
    Maybe a clip got disconnected accidentally
    Sounds like the you only worked on the Driver side. You can look at the passenger side to see if everything looks, the same, in reverse.
  4. Mar 14, 2024 at 10:49 AM
    Minou87
    Cat
    Thank you so much for your responses.
    I guess I didn’t explain myself correctly… the exterior handle was replaced with a genuine toyota handle. I can open from the inside handle just fine, (those cables for the lock and interior door handle work fine) it’s the exterior handle that isn’t connecting to the mechanism.
    Any blow out diagrams I find don’t show the actual mechanisms and how they connect/work with each other behind/between the actual steel door panel. I’ll throw a camera in to see what isn’t connecting and see what I can find.
    I was trying to avoid opening up the passenger rear door to compare
    The video posted above is exactly what I followed, but once reassembled in reverse, i can’t open the door with my exterior door handle- the interior handle works just fine with the cables reconnected.
    Stevie17 and Toyko Joe like this.
  5. Mar 14, 2024 at 5:36 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    I had this happen on my passenger side front only you couldn’t open it from the inside. The latch cable has a slot that it slides into and if it pops out you can pull on it and nothing happens. Remember it’s always something simple . :thumbsup:
  6. Mar 14, 2024 at 10:20 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I had a similar problem with my Access Cab, when I put the panel back on I was not successful in aligning something up and pinched a mechanism. Test while you have the panel off to see if it works, it is also much easier to see how something works when you can indeed see it.
