Changed the plugs on my 2010 first time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country, Mar 24, 2018.
  1. Mar 24, 2018 at 8:00 AM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    My 2010 has 102,000 miles on it. I decided to change the spark plugs and throw some bosche double Iridium in it. Mind you the plugs are factory original. I took all 6 plugs out. The driver side had NGK plugs and the passenger side had Denso plugs. Anyone know why a factory truck would have 2 different plugs in it? Anyone else seen that before? 20180323_151735.jpg
  2. Mar 24, 2018 at 8:00 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    That’s just how they come from the factory.
  3. Mar 24, 2018 at 8:02 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I believe it has to do with sharing the wealth.
  4. Mar 24, 2018 at 9:28 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    From what I'm told, you buy replacement plugs from Toyota and you get Denso/NGK mixed set. Back when I raced dirt bikes years ago, NGK supplied me with plugs. Still use em to this day. I run their irridiums. Very satisfied!
  5. Mar 24, 2018 at 9:42 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Only 70,000 miles overdue :rofl:
  6. Mar 24, 2018 at 9:44 AM
    DrFunker
    DrFunker Well-Known Member
    just numbers. :D
  7. Mar 24, 2018 at 9:46 AM
    inwood customs
    Dave
    I was shocked by the numbers at the gas station the other day.
    $4.16 a gallon?
  8. Mar 24, 2018 at 9:48 AM
    DrFunker
    :eek:
  9. Mar 24, 2018 at 9:52 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Normal....except the fact that this should be almost the 4th time to change em :D you should easily pick up a mile or two per gallon and the truck should run a lot better!
    Country[OP] likes this.
  10. Mar 24, 2018 at 10:09 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I jut bought some from Toyota and they just give you the Denso plugs. They said they have less issues with the Denso over the ngk.
    kimo likes this.
  11. Mar 24, 2018 at 10:28 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    My dealer told me just the opposite...
    Comparing both in truck with both brands used in concert seem to indicate no difference.
    Another reason why I dont listen to dealers.
    They tend to be self-serving.
    At any rate...last set of NGKs ran me 110k miles and looked good when changed. Insignificant difference in fuel mileage when changed. I saw little if any drop off in mileage over the plugs life span. Good plugs with modern Hei ignition last 100k +. More difference with dirty to clean air filter change....
    MattCowsmasher likes this.
  12. Mar 24, 2018 at 11:17 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Mine were the same way denso/ngk I went with denso for replacement.
  13. Mar 24, 2018 at 1:17 PM
    moondeath
    Pa, Gardners
    It was a mechanic/parts guys that told me that. He said they see less issues in the shop with the denso. Either way, they would make no more with either plug. Anyone from this area that deals with Rahal Toyota, also will agree that they are a decent dealership. They’re straight forward and no BS. Most dealerships are horrible, but these guys are very customer service oriented.
    kimo likes this.
  14. Mar 24, 2018 at 2:08 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Rather than rely on anecdotal comments from dealership mechanics hawking a product that is made by a division of Toyota (Denso) I tend to rely on independent testing done by 3rd party testing labs. In 4 seperate reports, NGK ranks 1, 1, 2, an 1 for reliability Best Denso rated was 4th in one test, low of 7th.
    It's also telling that while Denso is a spin off company started by Toyota, they still use NGK as their primary source for plugs.
    Long story short I suspect they BOTH exceed standards required for normal use.
    I've owned 5 Toyota trucks.....1st 4 logged over 300k miles. (1 over 500k) current truck close to 150k. Never had ANY ignition related problems or failures. I always run plugs 90k to 125k between changes. I tend to get above average mpg.... Just lucky I guess.
  15. Mar 24, 2018 at 2:25 PM
    inwood customs
    Dave
    Ngk is toyotas primary source for plugs but use 50/50 on our trucks?
    As in, most other yotas run only ngk from factory?
  16. Mar 24, 2018 at 2:32 PM
    dalero
    dalero Active Member
    dale
    RI
    2007 SR5 dcsb 6sp man 4x4 radiant red 70k
    alpine head ultra performance wheels new factory frame and leafs
    I guess it's better to be half right than all wrong.
    BWilley likes this.
  17. Mar 24, 2018 at 2:40 PM
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Never really ever heard of spark plug issues... if installed correctly and gaped correctly.
  18. Mar 24, 2018 at 4:04 PM
    moondeath
    Pa, Gardners
    I think your getting a little too serious about our spark plugs....
    gunn_runner likes this.
  19. Mar 24, 2018 at 5:14 PM
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    a little anti seize on the plugs is a good idea too.
  20. Mar 24, 2018 at 5:19 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I work on other peoples trucks. They deserve the best.
    lynyrd3 and kimo like this.
