Changed the spark plugs today...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyotatacomaTRD, Oct 8, 2010.
  1. Oct 8, 2010 at 4:42 PM
    toyotatacomaTRD
    toyotatacomaTRD [OP] Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Do these look normal? I had the dealership change the plugs (I had them give me the old ones).. It seems the NGK's are a little dirtier, one more than the others.
    My truck has 50k on it, I bought it used with 37k, so I am not sure if the previous owner changed at the recommended 30k, do they look like they were? I am no expert. Just wanted to hear your opinions.
    Thanks in advance for your help.
  2. Oct 8, 2010 at 4:47 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Looks like the ones installed from the factory to me.
  3. Oct 8, 2010 at 4:48 PM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    If the other three plugs are Denso, then chances are the previous owner didn't change them and they are the original plugs. Toyota for whatever reason has half Denso and half ngk on the tacomas off the factory floor.
  4. Oct 8, 2010 at 4:50 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    WTF!!!????
  5. Oct 8, 2010 at 6:04 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    definitely look like factory and definitely look beat to shit
  6. Oct 8, 2010 at 6:10 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Factory Plugs and looks normal! You're good! :D
  7. Oct 8, 2010 at 6:14 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    this...
    and this :)
  8. Oct 8, 2010 at 6:20 PM
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    Thanks for all of the input guys.. So, I am guessing the consensus is that they were the originals.. With that being said, I am wondering if I am going to see increased fuel mileage? I typically have been getting 17.5 to 18 per gallon. I guess we will see if that will go up.
    Other than chances of lost fuel economy, do I have anything else to worry about for letting plugs go that long?
  9. Oct 8, 2010 at 6:45 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    They are what ignites the a/f mixture...they arent done once the cars started. Everytime a cylinder explodes is because air and fuel get ignited by a spark plug. If there isnt a proper spark then the explosion sucks
  10. Oct 8, 2010 at 6:45 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Not glow plugs, spark plugs lol :) operates all the time when the gasoline engine is running.
  11. Oct 8, 2010 at 6:55 PM
    JustMe
    JustMe Active Member
    :confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
    Every compression stroke gets a spark.....
  12. Oct 8, 2010 at 6:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  13. Oct 8, 2010 at 7:08 PM
    JB3CK24
    JB3CK24 Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    4 Stroke Engine:
    Suck - Squeeze - Bang - Blow
    Suck = Air is drawn into engine cylinders via the valves opening up when piston moves downward from the crank rotating upon start up. Air is now present in the cylinder since it was drawn in and the piston will travel back up from inertia.
    Squeeze = Phase where Piston moves up in the cylinder compressing the air and injectors spray fuel into the cylinder. All valves are closed at this point.
    Bang = Spark plug ignites this Mixture of air/fuel sending piston firing back down.
    Blow = Cylinder travels back up after moving down and expels all exhaust gases out again and starts the cycle once more. This stage, exhaust valves are open.
  14. Oct 8, 2010 at 7:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    They look original to me. Even more worn out than mine were at 42K. My MPG didn't change when the plugs were replaced.
  15. Oct 8, 2010 at 7:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yup, it's true. NGK on one side, Denso on the other. Mine was the same way. Being fair to their suppliers maybe? The Densos seem to hold up better.
  16. Oct 8, 2010 at 7:23 PM
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    Agreed.. The Denso's were definitely cleaner (see pic on original post). The dealership replaced with 6 NGK's.. I will change in 30k for sure next time.
  17. Oct 8, 2010 at 7:35 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Obviously the original plugs. I cant imagine anyone (other than Toyota) would put in two different types of plugs.
    I could see it now, someone telling their parts guy "Oh you don't have six of the densos well give me three densos and three of the other kind.":D
  18. Oct 8, 2010 at 7:54 PM
    pinktaco808
    pinktaco808 Hot Steppa
  19. Oct 8, 2010 at 7:55 PM
    tonyplanet
    Glendora, CA
    I changed at 30k miles. All Denso plugs from Toyota dealership. Didn't notice any increase in mpg. I also ensured the gap of the plugs were within spec. The plugs were pre-gap from Toyota double checked myself.
    Not to be off topic. But I have new plugs and my rear diff changed out with Mobil synthetic. And still no improvement in mpg. Low fuel lights up at 296 miles.
  20. Oct 8, 2010 at 8:40 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    :eek: wow
