Changed Transmission Fluid-60k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachMX, Dec 16, 2011.
  1. Dec 16, 2011 at 7:27 AM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Just had the dealer drain and fill my transmission fluid (I do everything else DIY) but didnt wanna risk it with this. The service tech let me watch and check the fluid, at 59k still very red and no burnt smell. So those of you that are waiting to the new 60k recommendation, think your safe, based on what I saw think the 30k is a waste of money, but whatever helps you sleep at night. Just wanted to give you an update. Oh and dealer cost was $170 for drain and fill.
  2. Dec 16, 2011 at 12:25 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    how many quarts?
  3. Dec 16, 2011 at 12:27 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    do you tow?
  4. Dec 16, 2011 at 1:29 PM
    ZachMX
    From the invoice it looks like 4 quarts.
  5. Dec 16, 2011 at 1:30 PM
    ZachMX
    No towing, but I do haul 2-3 dirtbikes every other weekend.
  6. Dec 16, 2011 at 1:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good to know, I've been holding out til 60k miles to do mine.
  7. Dec 16, 2011 at 2:05 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    what about flushing?
  8. Dec 16, 2011 at 2:14 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Which dealer in Az did you use? Sorry to bombard ya with all the questions :)
    Azbackcountry
  9. Dec 16, 2011 at 10:34 PM
    ZachMX
    Desert Toyota im in Tucson
  10. Dec 16, 2011 at 10:36 PM
    ZachMX
    Dealer said they dont flush anymore with trannys. There's also a thread on here with a former Amco employee who said they wouldnt flush as well.
