Changes in hub size 2005 to 2009
Discussion in '2nd Gen. Tacomas (2005-2015)' started by High-Gear, Oct 21, 2010.
  1. Oct 21, 2010 at 2:56 PM
    High-Gear
    High-Gear [OP] Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    Hello All.
    I picked up a set of Ivan Stewart wheels from a fellow member here who was running them on his 2005 pre-runner. When I got them home I found out the hub bore is much smaller than on my 2009 4x4 off road. His wheels hub bore measured roughly 3 1/4 inch, and on my wheels they measure roughly 4 1/4 inch.
    I thought all the newer trucks had the same hub size. When did the hub size change? I need to know as I am looking for some used wheels for spares, and need to see which years to look for.
  2. Oct 21, 2010 at 3:11 PM
    Di Trut
    Di Trut Well-Known Member
    did you see these wheels mounted on his truck? he could have been running the wrong size bore.
  3. Oct 21, 2010 at 3:12 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Was his truck a PreRunner? Or a 5 lug tacoma?
  4. Oct 21, 2010 at 3:12 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    He might have been running wheel spacers.
  5. Oct 21, 2010 at 3:28 PM
    High-Gear
    Newton, KS
    09 TRD Off Road
    Ok,
    I guess I should have checked before posting (Face Palm)!!!!
    I looked at the back side of the wheel and it has a larger recess for the hub. The wheel has an area which surrounds the front of the hub and has a smaller size. I imagine this is so they can be sold for both the Toyota's and Chevy applications with the same 6 lug pattern. I bolted one up to my truck and it fit just fine.
    So there is nothing to look at here. Move along, nothing to see. Keep moving.
    Thanks for the input guys!
  6. Oct 21, 2010 at 3:29 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
  7. Oct 21, 2010 at 3:33 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    And its Jester with the perfect meme!
  8. Oct 21, 2010 at 5:59 PM
    High-Gear
    Newton, KS
    09 TRD Off Road
    Thanks Jester! I owe you one!!!!
