Changing A/C clutch pulley bearing???
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Jul 24, 2012.
  1. Jul 24, 2012 at 3:51 PM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    So my AC compressor clutch pulley bearing is definelty bad. Does anyone know the details behind its removal.
  2. Jul 24, 2012 at 4:29 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    are you talking about the actual ac unit or the idler bearing at the very bottom of the motor?
  3. Jul 24, 2012 at 5:25 PM
    x2468
    Pulley on the unit. I checked the AC idler and its good. No play or noise
  4. Jul 24, 2012 at 5:30 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
  5. Jul 24, 2012 at 5:36 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    the instruction should come with the new clutch assy. but if not ten mm socket and snap ring pliers. should come right off. if not dont bang it to much youll f up your compressor. get a puller from autozone or what ever they rent them.
  6. Jul 24, 2012 at 11:13 PM
    x2468
    item 14 is not listed in the parts list? isn't that all i need really? Thanks for the instructions though. I might pull the bearing and see if i can find the same profile bearing from all-balls or something.
  7. Jul 25, 2012 at 6:17 AM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    Yes but they only sale it as an assy. If your going the bearing rout then two sockets and all threadwashers and nuts. On socket fits the outer edge.on the other socket will let the bearing fall into it
  8. Jul 29, 2012 at 11:28 PM
    x2468
  9. Apr 4, 2014 at 4:15 AM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    Hey OP I'd your still around did you replace them? If so do you know the number on the bearings? Where did you get them?
  10. Oct 13, 2015 at 4:47 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Knock... knock. I think this is my problem. Any updates?
  11. Aug 28, 2017 at 8:25 PM
    wolverine8
    wolverine8 Well-Known Member
    MV
    06 Sport 4X4 - SR5
    Stock
  12. Aug 28, 2017 at 8:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  13. Aug 29, 2017 at 2:44 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Then let me add to the fun:
    How to remove and reset belt tension:
    How to replace a bearing without a hammer:
    No need for the bad attitude - if your post had anything like "for future reference" then it would have been easier to see you weren't actually accidentally resurrecting a zombie thread. It's recommended to start your own thread rather than resurrect an old one. You could have put something similar to "Replacing AC A/C Pulley Solved" or the like so that when someone searches they know to look at your thread first. Then you can put all the pertinent information in one spot for them to find. There's also the DIY repair / mod thread if you really think you've got something helpful to share - I know this won't necessarily come up on a specific internet search, but once someone's a member they might learn something while searching through it since it's a sticky in the first gen section.
    https://www.tacomaworld.com/threads...-thread-compiled-list-of-helpful-links.95271/
    There's a similar sticky for 2nd gens:
    https://www.tacomaworld.com/threads/2nd-gen-tips-mods-more.7174/
    Thanks for being helpful - it is what this community is all about. Keep up the good works sans negativity. :thumbsup:
    Jon G likes this.
