Changing a u bolt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blue-steel, Mar 31, 2018.
  1. Mar 31, 2018 at 2:09 PM
    Blue-steel
    Blue-steel [OP] Well-Known Member
    Is it okay to change a u bolt without lifting the truck onto jack stands and taking the wheels off? If I took the u bolt off, will the leaf spring pop out of place? I’m replacing a temporary u bolt with an actual one.
  2. Mar 31, 2018 at 2:19 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, best way to change it. Should only be torqued with it on ground also.
