changing axel fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Jan 17, 2011.
  1. Jan 17, 2011 at 10:04 AM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
  2. Jan 17, 2011 at 10:24 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    yes. ...the fill hole on the front diff is a 10mm hex/allen. it's usually in there pretty tight ..so you may need to get a hardened socket. i twisted my cheap 10mm hex trying to get it loose.
    and you can use synthetic without changing the seals.
  3. Jan 17, 2011 at 10:35 AM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    i also found it helps to use a syringe on the rear. i got a real big one when my daughter was born it makes filling them alot easier.
  4. Jan 17, 2011 at 10:37 AM
    bowhunter11199
  5. Jan 17, 2011 at 10:55 AM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    Do the Rear Diff breather extension mod so your rear seals dont blow up like mine did and cost you 1000 bucks.
  6. Jan 17, 2011 at 10:56 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i think that's correct. ...just check your owners manual ..it tells you what to use.
  7. Jan 17, 2011 at 11:40 AM
    bowhunter11199
  8. Jan 17, 2011 at 1:08 PM
    bowhunter11199
  9. Jan 18, 2011 at 10:05 AM
    SlimDigg
    Calgary, AB
    I've never been through water. I think snow and ice buildup plugged mine. The breather is for the oil to expand and contract for temperature changes. Should have came extended from stock.
  10. Jan 19, 2011 at 6:16 PM
    bowhunter11199
  11. Jan 19, 2011 at 6:23 PM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
  12. Jan 19, 2011 at 6:58 PM
    bowhunter11199
