Changing battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dinasour73, Dec 20, 2023.
  1. Dec 20, 2023 at 5:59 AM
    Dinasour73
    Dinasour73 [OP] Active Member
    Rickard
    2020 Tacoma Barcelona Red
    None
    When battery is disconnected does the OB computer loose the code for the radio to work?
  2. Dec 20, 2023 at 6:13 AM
    Scotty61
    Scotty61 Member
    Scott
    Northern Ontario, Canada
    2016 tacoma LTD
    Nope, you may loose your preset radio stations. Hondas' have a dedicated radio code.
  3. Dec 20, 2023 at 8:37 AM
    wayne0
    wayne0 Well-Known Member
    In order to keep your presets, hook up a 9v battery to your cables while swapping, or a trickle charger, if you have one. If a keyed version, you can plug it into the cig. lighter with the key on. Lighter shuts off with the key.
  4. Dec 20, 2023 at 8:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No radio code.
    You don't lose radio station presets either.
    The only thing you lose are your last-used climate control settings and mirror compass zone presets.
    NorrinRadd likes this.
  5. Dec 20, 2023 at 8:51 AM
    Bishop84
    Bishop84 Well-Known Member
    Just disconnect it, the radio saves presets.
    Big thing, dont start it after reconnecting, turn the truck to on (2 button presses on the start button if you have it), let the radio boot and systems start. After the radio boots, then start the truck.
    This usually allows the throttle to learn its shut position and prevents issues with idle as well.
  6. Dec 21, 2023 at 2:48 AM
    Dinasour73
    Rickard
    None
    That's good news. TKY
  7. Dec 21, 2023 at 9:10 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Didn't notice anything out of the ordinary.
  8. Dec 21, 2023 at 3:36 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Replaced my battery and drove away. Absolutely nothing changed, nothing lost!
    Stevie17 and Chew like this.
  9. Dec 21, 2023 at 7:13 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    You will most likely see an unusually high estimated range your first fuel tank after you change and several after as I believe the memory or trip cache is cleared but your Taco will re-learn range and the number will come back down to what you usually see.
  10. Dec 21, 2023 at 8:35 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Is radio still a thing?
    I kinda liken the 'radio' to calendars, and their days are numbered.
    AmateurTaco1313 likes this.
