Changing brake pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by spasur, Jan 7, 2010.
  1. Jan 7, 2010 at 3:06 PM
    spasur
    spasur [OP] Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    I've got about 119k on the original brake pads and pretty soon I'll destroy my rotors if i don't get them changed. I've never swapped out pads before, but based on a few internet videos I've watched it looks pretty easy.
    Are there any tips/tricks/special tools that will help me get the job done? What tools will I need? Is there a sticky I've overlooked that covers all this stuff? thanks
  2. Jan 7, 2010 at 3:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you are just changing pads.....all you gotta do is remove the clip and pull the 2 pins out. i would suggest taking the rotors off and getting them turned,so that the pads will wear even.
  3. Jan 7, 2010 at 3:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    then pull the pads out and change them. taking the rotor off.....gotta revove the 2 caliper bolts and pull the caliper outta the way.
  4. Jan 7, 2010 at 4:54 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  5. Jan 7, 2010 at 4:55 PM
    CraigTRD
    CraigTRD Canadian in the South
    Craig
    London, Ontario, Canada
    Tacoma
    6" FabTech Lift, Custom rear leaf packs, RedLine gas hood props :D, Hockey Stick Canadian Flag Mod. 2012 Front
    Make sure the sliders are lubed, and free.
  6. Jan 7, 2010 at 5:06 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    u might need a C clamp!
  7. Jan 7, 2010 at 5:09 PM
    CraigTRD
    Craig
    Tacoma
    OR, after you have the caliper loose and are about to take it off, pry it so that the caliper piston retracts back into the caliper....like use the rotor to press on the pads to open up the gap between the pads......am I explaining it properly? Does that make sense?
  8. Jan 8, 2010 at 7:20 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    spasur,
    If those "caliper/pad". pins are original ,buy new ones.....;)..
    You can save the old ones for spares IF they come out straight ( mine did not :rolleyes: )
    I would take the rotors off and have them "Mic'd",if they still have enough "Meat",turn them..if not upgrade to a new set....PLEASE do not make this decision solely on price....the 1st set lasted how long?;)
    When reassembling REMEMBER to lube those slides ( where the caliper moves ) install the rattle plates on the pads and apply the anti squeal "Lube" or spray......bolt it back up and recheck EVERYTHING ....Then bolt those wheels on and "Drive it".....oops,:D:D 1st and "ad" another step to your "Toyota can-do" list.....
    S
  9. Jan 8, 2010 at 7:43 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    C-clamp, beer, time, rock/classic rock music, you'll be ok. Shouldn't take more than an hour 1 1/2 tops to do both sides.
  10. Jan 8, 2010 at 10:54 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    There is a "sticky" on the 2nd Generation forum.
  11. Jan 8, 2010 at 10:35 PM
    genuitybits
    genuitybits Member
    PreRunner Base Model
    Sort of a noobish question, but those two bolts that are holding the pads in, how many ft lbs is the torque spec? Mine are in pretty tight and I was wondering if they are even screwed in. I cheated when I replaced mine and took the whole caliper off and I slipped the pads off from the inside. I know your supposed to clean the hardware but did not have the time to do it properly.
  12. Jan 9, 2010 at 4:24 PM
    spasur
    New Orleans
    02 PreRunner 4cyl
    Thanks for the tips, I'll pick up some new pins this week.
    I don't have any C-clamps, but I've got some channel locks and stuff to pry with, so it sounds like I'll be ok...
    Snoope, you're probably right...so I decided to order some new powerslot rotors from the groupbuy. At that price I really couldn't resist it for a bunch of reasons...
    1. I'll have all new (or mostly new) brake hardware
    2. I won't have to track down a shop that's open on saturday
    3. If the old rotors are out of spec, I'd have to buy new ones anyway, at least these are nice rotors and not cheaper ones from autozone, at about the same price
    4. I won't have to leave my truck up on jackstands in the street for half a day, yuk
    5. I will know my brakes won't need any servicing for another ~120k
    6. Because the pads I've got are already darn close to wasting the rotors, I won't have to worry about going beyond the point of no return
    7. Apparently I like to make lists...
    One more question...if I'm replacing my rotors, should I just swap out the pads before I take off the caliper, or should I do it while the caliper is off?
    Thanks again everybody!
  13. Jan 9, 2010 at 11:24 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I think it would be best to swap your pads first, so that you dont scratch or damge your new Rotors. then take the caliper off, to swap rotors.
  14. Jan 19, 2010 at 2:09 PM
    spasur
    New Orleans
    02 PreRunner 4cyl
