changing dash lights to a different color?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Mar 2, 2012.
  1. Mar 2, 2012 at 11:24 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    Has anyone changed all the lights in the truck to a different color? Dash lights an knobs lights? Is it hard? witch size of lights do i need. They are on ebay for cheap . Any pics or links
  2. Mar 3, 2012 at 2:01 AM
    TacomaV6
    TacomaV6 Well-Known Member
    Bay Area
    1997 Tacoma 2WD v6
    Brush Guard Hid lighting Custom Prelude Fogs
    not sure if its same for trucks. if you gonna change your lights to led I recommend doing a led strips. cause i am sure once you pop out the dash there is maybe around 4-6 bulbs and when you put led your car is going to have hotspots so basically some parts of your dash wont be as bright. you need to do a full converison
    p.s the ebay one I tried on my previous car sucks. its not bright and they burn out quick. cheap
    http://autolumination.com/74.htm
    try this site and see if they have the correct bulbs.
    without hotspots
    http://www.streetfx.com.au/product_images/leds/supra4.JPG
    with hotspots
  3. Mar 3, 2012 at 7:02 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Try these two links. For the most part just type LED dash lights in the advanced search page and only search under 1st gens. You may find more but this is what I got back when I was browsing for info a few weeks ago.
    How to:
    http://www.customtacos.com/tech/index.php?article=297
    Bulb Sizing:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/128857-first-gen-bulb-types-fyi.html
    When I bought bulbs for my interior MAP lights and Dome light, as well as gear shift indicator light, I just bought them all from superbrightleds.com which seems to be pretty quality lighting. Shipping was fast and I think there is a 5% discount coupon I saw floating around on here not long after I bought mine:/ I assume usually eBay light bulbs are either junk or can be potential junk, i.e. they work at first then burn out in maybe 4 months.
  4. Mar 3, 2012 at 7:26 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    See my sig for my LED build with links to what you need to buy...
    Bert6572 likes this.
  5. Mar 3, 2012 at 8:06 AM
    TacoBill35
    TacoBill35 Member
    Bill
    SoCal
    00 Tacoma TRD V6
    Just replaced the 2 lights behind the climate control panel with LED's (74-G) from superbrightleds.com. They are super bright for sure as you can see from the 2 bright spots.
    The green is a tad off from the dash lights, but close enough for me. Better than the burnt out build I had before.
  6. Mar 3, 2012 at 8:15 AM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
