Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 19, 2009 at 11:26 AM
    #181
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Either way, Buddy. I may give it a go.
  2. Jun 19, 2009 at 2:40 PM
    #182
    Blaise22
    Blaise22 Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    That was my first choice up until I heard that RP has shearing problems according to hokiemule a few post back so I just dont know:confused:.
  3. Jun 19, 2009 at 2:42 PM
    #183
    Blaise22
    Blaise
    California
    I hear ya, Sorry about your unemployment sitch:(
  4. Jun 19, 2009 at 2:48 PM
    #184
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worries, Bud. Everything will work out. :)
  5. Jun 19, 2009 at 4:33 PM
    #185
    hokiemule
    hokiemule Member
    Round Lake Beach, IL
    06 Tacoma 4WD
    Bone stock, for now.
    I don't have any experience with the RP myself, but a very knowledgeable and respected friend and member of another car forum said he strongly discourages people from using RP because it is more prone to shear. He recommends Amsoil or Redline MT90. There are discussions about it on a number of other forums.
    I am very pleased with the MT90 in my Spyder.
  6. Jun 19, 2009 at 7:58 PM
    #186
    Blaise22
    Blaise
    California
    Thanks for the info, I think im going with the redline.
  7. Jun 20, 2009 at 2:59 PM
    #187
    t800
    t800 Member
    houston
    2007 prerunner
    Alright I'm ready to try and change my diff oil. Is Valvoline brand going to be ok? I bought a 24mm socket and studied the steps and I think I'm ready.
  8. Jun 20, 2009 at 3:24 PM
    #188
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    Valvoline should be fine, 75 -90 or 80-90 weight. Remember your LSD additive if you are such equipped and dont forget your drain pan or bucket.
  9. Jun 22, 2009 at 6:13 AM
    #189
    ChrisL
    ChrisL Member
    Slidell, LA
    07 Dbl cab, TRD, 4X4
    What size is that hex socket for the front differential fill/drain plugs? And did you have to remove the skid plate to access it? If so what size socket did you use for the skid plate?
  10. Jun 22, 2009 at 6:49 AM
    #190
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    you do have to remove the skid plate, i forget if the bolts are a 10 or 12 mm, and the fill and drain plugs are a metric 10 hex.
  11. Jun 24, 2009 at 2:50 PM
    #191
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I have a 2009 access cab 4x4, with e-LSD (not clutch-type). I just looked at the rear diff housing, and a sticker directed me to see the owner's manual for details on the type of gear oil. The manual mentions no requirement for LSD additive - I'm thinking this makes sense - am I correct?
    I read this enitre thread but...
    ...if I replaced the front and rear diffs and the transfer case with the appropriate amount of 75W90 "dino" gear oil in each, does anyone foresee a problem? (Owners manual calls for 75W85 for the diffs, but I can't find any, and the dealership "only sells the diff oil in bulk" - as I was told by two dealerships). Using 75W90 instead of 75W85 appears not to be a problem. I'm thinking of using Mobil 1 75W90.
    Thanks all.
    EDIT: I have the base model 4x4, and from the window sticker, I don't have LSD or a locker... so I'm almost certain I don't need the LSD additive.
    Tijuanataconut likes this.
  12. Jun 25, 2009 at 5:48 PM
    #192
    jandrews
    '09 FourDubDee TRD OR
    No need for the LSD additive. 75W90 will work fine, and Mobil 1 75W90 is available almost everywhere...it's synthetic, not dino, but synthetic is almost always a better choice in the case of 2nd gen Tacos...
  13. Jun 25, 2009 at 6:06 PM
    #193
    bigmooze
    Richard
    Belle River, ON
    Thank you muchly. Since 32,000 km is the interval between these fluid changes, synthetic it is.
  14. Jun 25, 2009 at 6:09 PM
    #194
    jandrews
    Subject to use of course. If your diff gets in water a lot or you tow often, change it more often...say 15 to 20,000 miles (MILES AND KM ARE QUITE DIFFERENT UNITS!).
  15. Jun 25, 2009 at 6:12 PM
    #195
    bigmooze
    Richard
    Belle River, ON
    True enough, thanks for the reminder. As yet, I've yet to submerge the diffs or tow anything... I know, pretty lame. But when I change the rear diff fluid I'll throw on the breather extension mod too, just in case.
  16. Jul 3, 2009 at 9:48 AM
    #196
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I sent you a Pm apologizing about not seeing this and answering you sooner, again I am sorry.
    You do not need to remove your skid plate to get to your diff. I can't find my allens to double check, but I believe it was a 10mm.
  17. Jul 3, 2009 at 10:37 AM
    #197
    jandrews
    Correct, 10mm Allen for the front diff. Yes, you will need to drop the factory ENGINE skid plate (rear portion only) to access the front diff if you have the OR package. The skid plate is bolted on with four 12mm bolts. You will need a 3" or great ratchet extension or socket driver to reach two of the bolts on the skid plate. It's in a small recessed area that will not fit the head of a ratchet.
    Manual says it takes about 1.6Qt of gear oil, mine took closer to 1.8...just fill until you get a bit of drainage out of the fill hole, then close her back up.
    Thank god I changed it...did the front diff today when the truck hit 1000 miles, and the stuff that came out was pretty rough looking...booger grey and milky, and this was the factory fill! I bought the truck new with 75 miles (retrieval and test drive) on it.
    Anyway, it's full of mobil 1 75w-90 now. Should be happy.
  18. Jul 3, 2009 at 10:46 AM
    #198
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I must have a different truck because I don't need to drop my skid. I walked out to check.
  19. Jul 3, 2009 at 10:52 AM
    #199
    jandrews
    Do you have the TRD Offroad? If so, do you still have the factory skid plates?
    This only applies to factory TRD OR skids.
  20. Jul 3, 2009 at 10:53 AM
    #200
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    My truck isn't TRD. I have the stock skid. I can't take pics at the moment camera is with GF. Our skids stop a good bit before the diff. No reason to drop or lower the back portion, that I can think of.
