Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Sep 18, 2017 at 6:21 PM
    #2341
    DesertSand
    DesertSand Well-Known Member
    San Pedro, CA
    2013 DCSB Nautical Blue
    Great write up. Made for an easy change
  2. Sep 19, 2017 at 12:31 PM
    #2342
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    did you feel any difference after changing it? my truck is about to hit 150k and im pretty sure i have the original oil in the rear.
    i want to do this but im not sure if i should just leave it.
    edit: looks like i wont be hearing from this person. 1 post since june
  3. Sep 19, 2017 at 12:39 PM
    #2343
    eon_blue
    Azusa, CA
    I would definitely change it if it's never been changed. As far as I know, it's only bad to flush the automatic transmission fluid if it's never been done before. Just to be safe, it might be good to get a higher quality gear oil (perhaps synthetic) that is meant for higher mileage components.
    99TacoDriver[QUOTED] likes this.
  4. Sep 19, 2017 at 12:43 PM
    #2344
    eon_blue
    Azusa, CA
    Gear oil breaks down over time and will start to lose its effectiveness quickly when it gets way past due for a change.
    Norton likes this.
  5. Sep 19, 2017 at 12:43 PM
    #2345
    99TacoDriver
    South Louisiana
    i want to do it, but im ascared
    if i do it and something messes up ill get the big ol "told ya so" from my brother
  6. Sep 19, 2017 at 12:45 PM
    #2346
    eon_blue
    Azusa, CA
    I'd let others chime in but if it were me I'd do it asap, the oil that's in there is likely broken down and it'll shorten the lifespan of your gears. 150k is a lot but I've heard of others that have pushed it longer. Not a good idea but it is what it is. There are some good additives out there you can buy that are meant for higher mileage diffs.
  7. Sep 19, 2017 at 6:08 PM
    #2347
    tacomaSquid2011
    tacomaSquid2011 2014 Tacoma DC TRD Sport 4x4
    Eugene
    Virginia Beach, VA
    TRD Sport 4x4
    Map light / Dome Light LED
    Did that gasket kit come with all the gaskets needed to perform the oil changes on the front and rear differentials and transfer case? Any issues with "chatter" noise?
    I have a 2014 DC TRD Sport 4x4. 52600 miles don't know if the diff/transfer oil was changed previously with scheduled maintenance by the dealer. I'm the only owner and bought it new in 2014.
    Thank you so much for this write up.
  8. Sep 19, 2017 at 9:52 PM
    #2348
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Just go to dealer for gaskets. I got the front diff "drain plug" gasket the other day and was like a $1.50
    TacomaCZman likes this.
  9. Sep 19, 2017 at 9:57 PM
    #2349
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1...
  10. Sep 21, 2017 at 6:31 PM
    #2350
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Easy peasy. Take fill bolt out first, take drain bolt out, drain, put new washer on drain bolt, install, torque, fill with appropriate amount of fluid, install and torque fill bolt. Probably will need a breaker bar to break the bolts lose. Also use a 6 pt socket. Drop spare for more room, but not necessary.
  11. Sep 25, 2017 at 4:42 AM
    #2351
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Can I use 80/90 in front and transfer, or is it to thick?
    @chris4x4
  12. Sep 25, 2017 at 6:00 PM
    #2352
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be fine with that.
    303tacoma[QUOTED] likes this.
  13. Sep 25, 2017 at 6:10 PM
    #2353
    303tacoma
    Rebecca
    Thank you :thumbsup:
    chris4x4[QUOTED] likes this.
  14. Sep 26, 2017 at 11:05 AM
    #2354
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I'm sure this was asked in one of the 120 pages but with the "fake" LSD on the 2013 would I need LSD additive?
  15. Sep 26, 2017 at 11:05 AM
    #2355
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Nope.
    diabetiktaco likes this.
  16. Sep 26, 2017 at 11:07 AM
    #2356
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    It's literally the first words of the first post
    NOTE: 2009 and newer trucks do NOT need LS Diff addative, or TRD Off Road trucks with the factory locker.
    PDXKid, xJuice and Norton like this.
  17. Sep 26, 2017 at 11:08 AM
    #2357
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I literally thank you for that.
    SwampYota and 303tacoma like this.
  18. Sep 26, 2017 at 11:09 AM
    #2358
    Suprajim54
    Jimbo
    Irving, TX
    :thumbsup:
  19. Sep 29, 2017 at 8:06 PM
    #2359
    skeighter
    skeighter Well-Known Member
    10 minute job, thanks to the writeup. But at 45k miles the fluid wasn't bad at all. Little darker than honey and transparent. Gonna get a pump for the next change. Was a bit messy squeezing it in from the bottle.
  20. Sep 29, 2017 at 8:18 PM
    #2360
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    If only fwy miles, shouldn't have been that bad
