Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. May 29, 2018 at 8:09 PM
    #2441
    mpivovar
    mpivovar Well-Known Member
    Alberta
    2011 Tacoma
    Just confirming in the first post of the instructions it says that LSD additive is not required for 2009 and newer rear diffs. Is this correct.
  2. May 29, 2018 at 8:24 PM
    #2442
    eon_blue
    Azusa, CA
    Correct...Toyota stopped putting true mechanical LSDs in the Tacoma by then.
    DoorDing likes this.
  3. May 30, 2018 at 7:59 AM
    #2443
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    great write up....... to many pages.... My head hurts reading through pages of everything lol.
    I have a 2014 TRD sport and I need to do everything Front diff, TC, and rear diff. Already bought my crush washers, now I just need oil. I am hoping I could use the same oil for everything. I always stick with mobil 1 synthetic motor oil, so can use I mobil 1 synthetic 75w - 90 gear oil for everything and have no issues?
    Or something else you guys recommend?
    Whats the deal with the rear LSD in the 2009 and newer trucks, do they not have clutch pads and that's why the additive is not needed?
    Sorry to beat a dead horse, but there isn't a thread that applies to 2009 and newer trucks.
  4. May 30, 2018 at 8:04 AM
    #2444
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    your avatar is hilarious
    no sticker on my rear diff, but I didn't want that to be the deciding factor because it could have fell off hitting a speed bump in the mall parking lot trying to pick up babes
    scottalot[QUOTED] likes this.
  5. May 30, 2018 at 8:09 AM
    #2445
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    Parts department guy was a dumb shit, kept giving me uhhhh yea answers sounded like a autozone employee. And the service department never answered their phone. I do not have my Toyota service manuel, its just a maintenance booklet but it doesn't say, what type or weight oil for the truck.
  6. May 30, 2018 at 8:10 AM
    #2446
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    anyone here have a Tacoma service manuel and read it to me? That would be so awesome : )
    scottalot likes this.
  7. May 31, 2018 at 2:11 PM
    #2447
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    You are good with 75W-90 on all.
    NAAC3TACO likes this.
  8. May 31, 2018 at 7:11 PM
    #2448
    TacomaCZman
    TacomaCZman Well-Known Member
    San Antonio, Texas
    2022 Tacoma SR5 Pre-Runner 3.5L 4x2
    Changed my rear axle oil today(this was the first time that I did the change). Used Royal Purple Max Gear 75W90. That replaced a BG synthetic. Got a smoking hot deal via eBay on 6 QT. Pretty straightforward job. Had a little difficulty removing the fill plug. Had to blast it three times with PB Blaster. Replaced the plug gaskets. Lowered the spare tire to make it easier to fill the axle.
    Torqued to 36ft-lbs. with a Tekton ½ torque wrench( 10-150ft-lbs.).
    Thanks to the OP for the writeup! Piece of cake, chocolate cake.:D
    ready6delta likes this.
  9. Jun 3, 2018 at 1:24 PM
    #2449
    Jc4x4
    Jc4x4 Well-Known Member
    Jordan
    Maine
    2014 4wd SR5
    Does truck need to be level to fill correctly? Starting to dribble out even after letting it sit for a few minutes. So I can't put in the 3 quarts
  10. Jun 6, 2018 at 12:09 PM
    #2450
    sikTacos
    sikTacos Well-Known Member
    Eric
    SoCal
    2Gen Tacoma (DC/LB/4X4)
    Sorry guys,
    Tons of pages to go through. I have a 2011 TRD Sport with 4x4.
    Will this be all I need to complete this maintenance:
    6 qts 75-90 weight gear oil (Front, Rear and TC)
    4 oz of LSD additive (what brand and do i refill the entire rear diff with only 4oz?)
    24mm socket
    Am I missing anything else? Thanks for the help in advance.
  11. Jun 6, 2018 at 12:59 PM
    #2451
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You don’t need the additive on a 2011, but your list looks good.
  12. Jun 7, 2018 at 8:37 AM
    #2452
    ready6delta
    JACOB
    Yes it should be level as if rolling down the road and shifting. You could tighten it back up drive around a little bit and then check the fill level again to see if you can fit the 3 qts but if it is coming out you should be good assuming you drained all the old stuff.
    Jc4x4[QUOTED] likes this.
  13. Jun 7, 2018 at 8:38 AM
    #2453
    ready6delta
    JACOB
    I got 7 qts just in case I needed a little extra or spilled to much but 6 should cover it.
  14. Jun 7, 2018 at 8:39 AM
    #2454
    ready6delta
    JACOB
    Good call seems to be popping up a lot lately.
  15. Jun 7, 2018 at 1:32 PM
    #2455
    sikTacos
    Eric
    SoCal
    Thanks man! Got a bit confused when OP said "Sport models require LSD additive".
    Now that I reread his post, it says anything newer then 2009 does not need the lsd additive, even if you have a sport model.
  16. Jun 8, 2018 at 11:08 AM
    #2456
    mpivovar
    Alberta
    2011 Tacoma
    Just wondering to get oil into the diff do you need a pump and hose that fits those 1 qt bottles or do those 1 qt bottles with the narrow tip fit in to fill hole and is there room to tip it up so it all goes in?
  17. Jun 8, 2018 at 1:02 PM
    #2457
    ready6delta
    JACOB
    Front diff will require a hand pump because of the angle. The rear diff and tcase (at least if your truck is lifted) I was able to just squeeze the bottles in. Non lifted trucks may vary with that. The rear diff definitely drop the spare tire and just squeeze in but tcase might be tight without a lift. Look at the bottom of the thread and the Amazon list has the basic stuff you need.
  18. Jun 8, 2018 at 3:14 PM
    #2458
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    All you gotta do is read a little. Clearly posted.
  19. Jun 8, 2018 at 3:16 PM
    #2459
    mpivovar
    Alberta
    2011 Tacoma
    Thanks. And being in Canada I hate looking at the Amazon.com links below. So depressing. Just below the 1qt of synthetic oil is $8.79USD that same qt in Canada in around $25 CAD which is about $20USD... so depressing seeing those prices and being in Canada.
    Saskabush likes this.
  20. Jun 9, 2018 at 2:14 PM
    #2460
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    Is there a correct direction for new crush washers? Rounded side (hump) towards the differential or the drain plug (bolt) head?
    Thanks!
    gulzeb likes this.
