Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 9, 2018 at 2:19 PM
    #2461
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Rounded side goes towards the differential.
  2. Jun 9, 2018 at 2:38 PM
    #2462
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    Thannks @SwampYota - I was just ready to put them in!
    SwampYota likes this.
  3. Jun 9, 2018 at 2:52 PM
    #2463
    SwampYota
    Jon
    Floor mats
    :hattip:
  4. Jul 20, 2018 at 9:34 AM
    #2464
    dblwall
    dblwall Active Member
    Az
    2012 TRD Sport
    Bought my Tacoma just over 1 year ago, had 65,000 on it. Getting around to the basics not sure of the previous service on it. This guide made it a snap. Have 1 question, only got about 2 1/2 qts out of the rear dif. Should I be concerned?
  5. Jul 20, 2018 at 10:26 AM
    #2465
    HansWorldTravels
    Hans
    Colorado/NY/Germany
    Lower than expected out, no longer matters as you're replacing & filling going forward. Remember to check/clean the drain plug magnet as this would be more telling of the state of the internal gears (i.e. Large or small or no fillings)
    ready6delta and NAAC3TACO like this.
  6. Jul 20, 2018 at 12:36 PM
    #2466
    dblwall
    Az
    2012 TRD Sport
    Just some fine particles on the magnetic plug. Really liking this truck so far.
  7. Jul 20, 2018 at 2:49 PM
    #2467
    robu
    robu Well-Known Member
    Rob1224
    Cottonwood, AZ
    TRD sport debadged
    kings front and rear 3" expedition deaver pack 700lbs in front. lighted 4x4 switch and fixed temp console
    did mine yesterday and got very small filings and what looks like some kinda round spacer/had a funny stamp in the middle. about a 1/4 inch in diameter.
    HansWorldTravels likes this.
  8. Jul 30, 2018 at 5:36 PM
    #2468
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Big thanks to OP, did mine this weekend. Piece of cake! Fluid had 50k on it and seemed clean coming out, but looked dirty when pooled in the collection bucket.
  9. Aug 4, 2018 at 9:16 PM
    #2469
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Changed my gear oil a week ago. It has not been changed since I got the truck with 67k miles on it. It had 196k miles on it when the drain plug was pulled. I was amazed to see the oil was still somewhat amber in color and light was passing through it. The drain plug did have metal covering it much like the other pics posted by others. I added 3 quarts of the Mobil 1 75W-90 Synthetic. I didn't have any flow out of the fill plug so I looked it up and it takes a bit over 3 quarts to reach capacity. Glad this went quickly because it started flooding as the fill plug was getting its torque treatment.
    Thanks to the OP for the how-to and all the feedback. One tip I have is when it's time to fill it back up, grab your tire tools and drop the spare to the ground. It will give you the clearance needed to tip the bottle up and get all the oil in if you don't have a pump or a fill tube to push onto the nipple.
    TheDevilYouLove likes this.
  10. Aug 5, 2018 at 7:31 AM
    #2470
    Babyruthless87
    Babyruthless87 Well-Known Member
    Joey
    2011 Tacoma TRD Sport DCSB
    I have. 2011 TRD sport. Do I need to put lad addative in bothe differentials?
  11. Aug 5, 2018 at 7:39 AM
    #2471
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    You don't need it in either.
  12. Aug 6, 2018 at 5:11 PM
    #2472
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Just changed my rear for the firsts time at 60k miles. Discovered a crush washer in the strainer in my catch pan after......
    The fill plug was the safest to pull and it didn’t have one, so my question is: should they both have them ?
  13. Aug 6, 2018 at 6:19 PM
    #2473
    hobiecat111629
    For those interested, both have them. I learned that after draining and refilling.....
    And always make sure that you borrow working tools. I borrowed a 40+ year old torque wrench from my dad and am 100% sure it isn’t accurate. I torqued it to somewhere around 40 because the needle was bouncing around, then decided to back it off and it only took 15 to loosen.....going to buy my own on the way to work tomorrow and double check.
    gulzeb likes this.
  14. Aug 7, 2018 at 1:46 PM
    #2474
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    My 2013 AC TRD OR 4x4 4.0 V6 requires the following (should be the similar for your 2015)
    Front diff drain plug washer (copper) = part #90430-24003, 48 ft lbs, ($1.74)
    Front diff fill plug washer (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    Rear diff drain plug (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    Rear diff fill plug (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    Transfer case fill plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Transfer case drain plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Transmission drain plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
  15. Aug 13, 2018 at 7:00 AM
    #2475
    Babyruthless87
    Joey
    Anyone ever have more than the required amount of oil go in and still not have any start to leak out of the fill hole?
    I stopped at just over 3 quarts. Wondering if I should keep going or stop there because I believe the recommend amount is just over 3 quarts.
    I have. 2011 TRD sport 4x4
  16. Aug 13, 2018 at 7:27 AM
    #2476
    TheDevilYouLove
    Marylandistan
    It holds 3.1 quarts, so you’re just about there.
  17. Aug 13, 2018 at 11:16 AM
    #2477
    Babyruthless87
    Joey
    I would say I’m at 3.5 quarts. I’m just not sure if I should keep going until it just starts to come out the full hole or stop where I’m at.
  18. Aug 13, 2018 at 12:14 PM
    #2478
    TheDevilYouLove
    Marylandistan
    Weird. Is the truck parked on level ground? Or is the nose pointed downhill?
  19. Aug 13, 2018 at 3:55 PM
    #2479
    Babyruthless87
    Joey
    It was in my driveway which might not be dead level but thought it was close enough.
  20. Aug 13, 2018 at 5:39 PM
    #2480
    TheDevilYouLove
    Marylandistan
    Hmmmm. Maybe drain it and measure how much comes out? Maybe a seal is shot and it’s leaking into the axle?
