Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Aug 1, 2019 at 6:29 PM
    #2541
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I’m a fan of removing the spare tire to do the rear diff so you can pour the gear oil in from the bottle. Good time to spray the tire hoist mechanism and cable with fluid film also.
  2. Aug 2, 2019 at 6:38 AM
    #2542
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
    Exactly what I did on my last fluid change. I also had the back end on jack stands with the rear suspension at full droop. In this configuration I was able to comfortably sit underneath and pour the fluid into the fill hole using the nozzle on the bottle.
    floodedkiwi likes this.
  3. Aug 10, 2019 at 2:12 PM
    #2543
    TheDevilYouLove
    Marylandistan
    Truck on level ground? Or was nose down a little?
    CraignGA likes this.
  4. Aug 10, 2019 at 4:33 PM
    #2544
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I just did my rear diff and transfer case this afternoon on level ground and my rear diff took 3.5 quarts. The old oil had 49,500 miles on it and it looked very good. The transfer case oil looked brand new. I need to pick up some more oil, because I only have a quart and a half (3 pints) and the front diff calls for 3.2 pints. Oh well. A project for another day.
  5. Aug 12, 2019 at 4:34 PM
    #2545
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    You're supposed to ask, "What's a henway?" Then he can give you the dad joke response.
    So what's the opinion on 75-90 synthetic vs 80-90 regular? The 75-90 will cost me about $60 for 6 quarts and I can get the 80-90 for about $20. Seems to me they both end up 90 weight when warmed up. Am I missing something?
  6. Aug 12, 2019 at 5:21 PM
    #2546
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    you be missing about $40 bucks if you run 75-90. :)
    i used Valvoline™ High Performance 80W-90 Gear Oil without issue.
  7. Aug 12, 2019 at 5:21 PM
    #2547
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    I used 80-90 in my rear diff and no issues so far. I live in GA so it doesn’t really get cold enough down here to worry about the small difference IMO.
  8. Aug 17, 2019 at 3:16 PM
    #2548
    NAAC3TACO
    2014 SR5 DCLB 4x4
    After doing the rear diff and t case last week, I finally got around to doing the front today. The oil looked similar to the rear, so I would suggest if you do one, you might as well do the other.
  9. Aug 24, 2019 at 11:28 AM
    #2549
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I replaced the factory 75w85 with synthetic 75w90 and noticed my gas mileage dropped about 1 mpg. I've only checked 2 tank fulls so far and it has been in the mid to high 90's where I live so the ac has been on quite a bit, but it feels like I have to push the gas pedal a little harder to get going even with the ac off. It could be my imagination, but I wanted to see if anybody else has noticed this.
  10. Aug 24, 2019 at 1:21 PM
    #2550
    asuchemist
    NONE
    I imagined the same thing. thought it was like i filled with molasses or something. In reality I am still getting under 20 and it's been 114 this week.
    NAAC3TACO[QUOTED] likes this.
  11. Aug 24, 2019 at 2:25 PM
    #2551
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I'm glad I'm not the only one that noticed this. It might just be the difference from going from old oil to fresh new oil. I know 75w90 is safe to use, so it's probably no big deal. Normally I get 18-19 mpgs this time of year, but since the diff service I'm getting 17-18.
  12. Aug 27, 2019 at 5:31 AM
    #2552
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    1 mpg.. That could be from anything. Safe to use.. ECGS/ARB recommends 85-140 when you get gears/lockers done, so as long as there is diff oil in it you are safe.
    iK0NiK and NAAC3TACO[QUOTED] like this.
  13. Aug 27, 2019 at 5:37 AM
    #2553
    TheDevilYouLove
    Marylandistan
    Yeah lots of guys use 140 weight so are they getting like 10 mpg?
  14. Aug 27, 2019 at 5:53 AM
    #2554
    Sandman614
    Tim
    '06 SR5 Off Road
    By the ideas brought forth here, yep.
  15. Aug 27, 2019 at 4:56 PM
    #2555
    NAAC3TACO
    2014 SR5 DCLB 4x4
    After I changed the gear oil in the rear diff, I immediately noticed it took a little more pedal to get going. I doubt it's from the 75w90 weight oil, but maybe I put too much oil in the diff. I filled it until some dripped out of the fill plug on level ground, however, it took 3.5 quarts, which is a little more than the 3.15 quarts (6.3 pints) it's supposed to take. Again, it's probably no big deal. I was just curious if anyone else had experienced this.
  16. Sep 16, 2019 at 9:45 AM
    #2556
    VTacoma6
    VTacoma6 Well-Known Member
    Vince
    Florida
    2015 Toyota Tacoma Trd Sport 4x4
    16 inch Matte Bronze FN Countersteer Type X wheels 0 offset With Goodyear Duratracs 265/75R16
    Do I add one tube of LSD additive to both the front and rear? Or do I only put it in one of the differential thanks!
  17. Sep 16, 2019 at 9:47 AM
    #2557
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not required, at all.
    VTacoma6[QUOTED] likes this.
  18. Sep 16, 2019 at 9:48 AM
    #2558
    TheDevilYouLove
    Marylandistan
    Don’t need it in a 2015
  19. Sep 16, 2019 at 9:50 AM
    #2559
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    pretty interesting, ive been using the REDLINE 75w85 in my rear diff since I bought the truck and I use 75w90 in the front diff/transfer case, to offset the high cost of REDLINE I was hoping on using SUPERTECH 75w90 in everything next the cost of REDLINE is too much but I can understand u losing some power/mpgs because that stuff is thin as water compared to 75w90
  20. Sep 16, 2019 at 9:52 AM
    #2560
    VTacoma6
    Vince
    Florida
    Thank you.
    Thank you.
    What was the cut off to needing the additive? I just went off the original listing in the form. Saw that I also had the sport.
