Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Nov 4, 2009 at 1:43 PM
    #341
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 3rd member....Its the front of the diff. Just pull the axels out about 6", disconect the drive shaft, and you can pull the front of the diff out.
  2. Nov 15, 2009 at 1:59 PM
    #342
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I just changed my oil for the first time on Friday, and wanted to comment on this, even though It's not a big deal.
    I changed mine after driving it with the oil hot or warm, and on level ground. I let it drain out completely on level ground without jack stands, then after that I wanted to lift the axle higher on one side to see if any more oil would come out.
    I lifted the left rear axle (drivers side) almost 8 inches and more oil did come out. It wasn't a lot though, but it did take about 5 minutes before it stopped draining.
    I then lifted the right rear axle (passenger side) just like the other side and absolutely no oil drained out at all. I kept it up for about 5 minutes just to make sure.
    So I'm not sure if it matters if you do this or not, but I would guess it really doesn't matter. Also I'm sure a lot of other factors play into this like the type of oil you use and how many miles you change it at and other factors.
    I bought one of those oil pumps (OEM), it worked good except the fitting did not screw into the Mobil 1 quart bottle. It screws into standard gallon size bottles, so make sure not to make the mistake I made and make sure it will screw into the quart size. Or pour the oil into a clean gallon container and use it that way.
    But thanks for the write up guys, it really helped me out a lot! :)
  3. Nov 15, 2009 at 3:05 PM
    #343
    Coheednme13
    Coheednme13 Well-Known Member
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    I'm overdue on this by about 1500 miles I just can't break my fill plug. I don't have a way to lift it and I don't have an impact wrench anyone have any suggestions :eek:
  4. Nov 15, 2009 at 3:14 PM
    #344
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The dealer will usually break a stuck plug for you, or try either a bottle jack under the wrench or a longer handle for more leverage.
    TacomaTrav likes this.
  5. Nov 15, 2009 at 3:37 PM
    #345
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Outting a wrench on the bolt, and tapping the wrench with a hammer works also.
  6. Nov 29, 2009 at 12:59 PM
    #346
    jjjewett
    jjjewett Member
    tahoe
    04 double-cab trd 4x4
    I took my stock 04' taco dc 4wd trd through clam beach creek last friday.
    It looked pretty much like the video below.
    http://www.youtube.com/watch?v=XD2nHT8_UDs&feature=related
    My truck has 58k miles on it and I just had the diff fluid changed.
    Should I rechange the diff oil and/or anything else because of this water crossing? I will look at the idler pulley, and have checked the air intake. there was some moisture in the bottom of the air box, but the filter was dry.
    I will do the diff breather extension after this, but wonder if I should change the fluid.
    I have driven for around 700 miles after the water crossing and everything "seems fine".
    thanks for any advise.
    -John
  7. Dec 23, 2009 at 7:21 PM
    #347
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    Hey guys, great thread.
    I'm gonna be doing my man-tranny, TC, and front and rear diff fluids this weekend. I have the 05 TRD SPORT with LSD and I'm WAY past due... 80K... whoops.
    Please make sure I'm understanding what I've read:
    - I can use synthetic in Front Diff, TC and Tranny... but I should NOT use it for the rear diff? Correct?
    - I need to add a LSD additive to the rear diff in addition to a non-synth fluid? One brand of additive better than another?
    - I'm seeing the brand name Redline being thrown around for the rear (or all?) If I can't get my hands on Redline, what standard autozone (or walmart, or NAPA auto...) brands are acceptable?
    Thanks so much guys. I figure it's so WAY overdue that I should be sure do get it right... and right away.
  8. Dec 23, 2009 at 10:48 PM
    #348
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    John, personally I have never had any effects from water but if you feel uneasy, theres certainly no harm in changing the fluid.
    Ryan, according to the tests Chris has run, synthetic in the LSD is not the best route. I used whatever cheapo 80-90weight dino gear oil that was at the shop I stopped at. Any dino 75 or 80-90 will do. As far as LSD additive is concerned, Chris grabbed the only product they had (its pictured in the OP). 4ounces of additive is what is needed.
  9. Dec 24, 2009 at 7:57 AM
    #349
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If you have LSD, there is no reason to run synthetic. You will be changing it every 30,000 miles anyway, just make sure you use the additive. If you have a locker or open diff, you can run synthetic and change it at a more extended interval. 2005 and up Corvettes actually had a problem running synthetic with additive so GM came up with Dexron LS fluid that is not synthetic and contains the proper amount of additive. Of course, that does not mean Tacomas would have an issue with synthetic, but my point is that LSD diffs and synthetic oils don't always mix. If my Tacoma had LSD, I would stick with Toyota's reccomendations. JMO.
  10. Dec 24, 2009 at 9:50 AM
    #350
    sonjay
    sonjay Well-Known Member
  11. Dec 24, 2009 at 9:55 AM
    #351
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Redline makes some great products. I plan on using their synthetic gear oils when I do my first service, including MT90 in the 5 speed. Thanks for the info about the LSDs.
  12. Dec 24, 2009 at 5:54 PM
    #352
    rclangelan
    Sykesville, MD
    Thanks guys,
    Where are you buying your Redine products from? I can't find the stuff locally.
  13. Dec 24, 2009 at 8:18 PM
    #353
    brianr
    2010 4x4
    as soon as I pick up my new Timberland Mica OR dbl cab next week. :D
  14. Dec 24, 2009 at 8:20 PM
    #354
    brianr
    2010 4x4
    I was just about to text you when I logged on brotha.
  15. Dec 28, 2009 at 9:58 AM
    #355
    cabsav214
    cabsav214 Active Member
    NOR CAL
    08 DC 4x4
    I see most of you use a 75-90 or 80-90 in the rear differential, On a 4x4, the manual says to use straight SAE 90. Is there any big difference there?
  16. Dec 28, 2009 at 2:32 PM
    #356
    jandrews
    '09 FourDubDee TRD OR
    Manual for my '09 4x4 says 75w-90 for both diffs and the t-case.
    Straight SAE 90 is just less vulnerable to temp change...may be a bit thicker in colder temps...
  17. Dec 28, 2009 at 3:37 PM
    #357
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Dec 28, 2009 at 3:44 PM
    #358
    jandrews
    :facepalm:
    Right. My bad. Got my fingers all twisted together again. Edited to fix. Good catch.
  19. Dec 28, 2009 at 4:02 PM
    #359
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! My fingers rarley untwist. :eek:
  20. Dec 31, 2009 at 8:23 AM
    #360
    HeadPin21
    HeadPin21 Member
    Alexandria, VA
    04 SR5 TRD Dbl Cab
    Rough Country 2.5"
    I just did the rear diff and transfer case, but i couln't get to front diff on my '04 taco. It looked like i would have to take off the A arm to reach the fill plug? I don't know how else to get at it so i may just take it to the shop and have someone else do it. I didn't see anyone else on here having this problem but I don't see any way around it.
