Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 21, 2009 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats an old myth. Synthetics are fine at any mileage:
    http://www.oilsandlube.com/myths.htm
    Myth #1: Synthetic motor oils damage seals.
    Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
    Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
    TRDSport10, RobA, kslade and 4 others like this.
  2. Jan 21, 2009 at 7:22 PM
    05DoubleTaco
    05DoubleTaco Well-Known Member
    Maryland
    2005 Lifted DoubleCab
    3" Toytec Lift, 285/75/16 Cooper STT, Moto Metal 951 Wheels, Magnaflow Exhaust, K&N Intake, URD MAF & Tune, Full Stereo w/ Marv Custom Box
    Yep, I had been wanting to do mine for a long time.
    Finally got around to doing it last month, and a good difference!
    I did both front and rear diff as well as the 6spd tranny.
    Used Redline products, good stuff!
    My rear diff fluid was just as I had expected, a little milky and metal shavings on the bolt. After 3 years of constant creek crossings, I knew it would be bad.
    TRDSport10 and Stryker420 like this.
  3. Jan 21, 2009 at 7:30 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Really....I thought that may have been why I had to replace my seals. They coincidentally started leaking after I switched to synthetic.
    ......oh well, good to know.
  4. Jan 21, 2009 at 7:34 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well if its nice this weekend, i may replace it then. How do i know if my seals go bad? oil leaks on the inside of the wheel?
    burntkat likes this.
  5. Jan 21, 2009 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  6. Jan 21, 2009 at 7:40 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    gotcha..thanks ya
  7. Jan 21, 2009 at 8:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just by chance.....have you tried royal purple?? i have heard quite a few people with the 2nd gen tacoma with the lsd diff that use it and say its smooth and quiet. may be worth a shot....even though i'd still add a lil friction modifier.
  8. Jan 21, 2009 at 8:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have heard that too, Will, but as I havent tried it, I thought I will wait until someone with first hand knowlege comes forward. Im going to stick with the Dyno oils. My truck sometimes sits in the water over the axel, and going in and out with the boat, I have to check it anyway, so I just change it. :)
  9. Jan 21, 2009 at 8:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i hear that man. pb hasnt been on here in a good while...but i know he has the lsd diff, and uses(or did) rp, and he had zero complaints. just a heads up anyway.
  10. Jan 21, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, hell. I guess I may have to try that out on my net change. :)
    loginfailed likes this.
  11. Jan 21, 2009 at 8:22 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Mmmmmmmmmmm diff fluid smell
    I hate that smell, I always get stuck doing the truck cranes @ work and I swear I can smell that crap for 3 days after.
    We at least have 5 gal pails with pumps so it goes pretty fast
  12. Jan 21, 2009 at 8:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let us know how it goes man.............cause if it works for the lsd, alot more people may switch over to synthetic if we find something that wont make the rear gears bark like hell like the mobil1 does.:D
  13. Jan 21, 2009 at 8:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, that why I figured I'd give it a shot. Just so we know for sure. ;)
  14. Jan 21, 2009 at 8:36 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Yeah, the only reason I mention it is that the gear lube I used came in quart bottles like engine oil bottles. They didn't have the tapered spouts like some other gear lubes do. Not sure how many other gear lubes come in the non-tapered bottles and it's a handy thing to have around for doing manual tranny and front diff fluid.:)
  15. Jan 21, 2009 at 9:05 PM
    #35
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey great write up chris and brian!!! This was exactly what I needed to know! Quick question. I know you need 3 quarts of oil but with the extra 4oz. of the lsd fluid, did you guys end up with some left over or were you able to get it all in?
  16. Jan 21, 2009 at 9:09 PM
    #36
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2 on this one!;)
    TRDZILA likes this.
  17. Jan 21, 2009 at 9:13 PM
    #37
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    The smell of gear oil makes me hungry....
    Good write up.....
    just did it last week in about 25 min!!!!
  18. Jan 21, 2009 at 9:27 PM
    #38
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Hey tacoman
    I did my front and rear diff with 75/90w Royal purple. I have the electric locker in the rear. The manual said replace at 15,000 miles and the stealer wanted $90 for the rear only. Took me about an 1 hr to do both. Have about 3500 miles on it so far and no problems. Do a lot of offroading and pulling a 3500 pound trailer about 2 a month.Hope this helps.
    By the way nice write up on this never thought of doing it. I take it for granted since I rebuild gear boxes on a regular bases at work.
    blm likes this.
  19. Jan 21, 2009 at 9:29 PM
    #39
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Dang I could have sworn my manual said every 30,000.:rolleyes:
  20. Jan 22, 2009 at 2:17 AM
    #40
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    X2
    Also, where do you dispose of the stuff? Will Autozone take it like they do with engine oil?
