Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 12, 2010 at 12:53 PM
    #381
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Yeah I was referring to Major Chris
  2. Jan 14, 2010 at 1:12 PM
    #382
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    just got done changing my rear diff fluid to mobil 1...easy as pie. thanks for the write-up or else i probably wouldnt have thought to do it. the fluid smells exactly like the transmission fluids we used on our helicopters in the Marines - it brought back some memories of being on the flightline. :)
  3. Jan 16, 2010 at 9:40 AM
    #383
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I dont want to sound like a mangina, since today it has warmer weather in NJ, I want to change the rear diff fluid, drove around for a bit... got home...BUT I CAN"T GET IT OPEN!!! THE FILL AND THE DRAIN PLUG!!! ANY SUGGESTIONs!!! I want to get this done before the cold comes back AGAIN!!! I can OPEN the transfer case!! BUT NOT THE REAR!!! I put a LOT OF power into it but still nothing, I dont want to strip it!!
  4. Jan 16, 2010 at 9:42 AM
    #384
    Jason'sLawnCare
    The only things I can think of are a bigger wrench or an impact wrench.:eek:
  5. Jan 16, 2010 at 9:47 AM
    #385
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Put the wrench on the fill plug, then tap the wrench with a hammer. AFTER the fill plug is off, then do the same thing to the drain plug.
  6. Jan 16, 2010 at 9:48 AM
    #386
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I think I need another suggestions!! :)
  7. Jan 16, 2010 at 9:49 AM
    #387
    Jason'sLawnCare
    listen to Chris's suggestion. That's a good idea.
  8. Jan 16, 2010 at 9:49 AM
    #388
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And....you are turning it the right way....right?? "Lefty = loosey"
  9. Jan 16, 2010 at 9:50 AM
    #389
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    Sir Isaac Newton here, ladies and gents!! *running towards my truck now*
  10. Jan 16, 2010 at 9:50 AM
    #390
    Jason'sLawnCare
    I turned it the wrong way because the drain plug is upside down and wondered why I had so much trouble. haha
    If I were you I wouldn't try to get the drain plug off until the fill plug is off.
  11. Jan 16, 2010 at 11:46 AM
    #391
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    How about an air gun ? The hammer action on the impact gun could help. You could try WD or Blaster but don't just spray it on, try tapping it with a hammer, not so you dent it but the vibration helps it to get down into the threads. One time I couldn't get a bolt loose even with the double wrench interlock trick, I sprayed it and tapped it with a hammer for a while and it came off like butter.
  12. Jan 16, 2010 at 2:20 PM
    #392
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i was turning it right...
    I got it off by listening to chris4x4 on the hammer tapping... on the drain plug..
    I was using the hammer tapping to get the fill plug off but I had trouble...
    so I used all my super human strength and got loose! I turned it so hard that my body bounced up and hit my truck and my glasses came off the same time... dont know why they turned it so tight from factory... frustration was kicking in... I only did my rear fluid change... did have time to go my transfer case, we were going out to cheesecake factory... SO GOOD!!!
    and thanks chris4x4!
  13. Jan 16, 2010 at 2:26 PM
    #393
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    oh also,,, when it was coming out, it was like this light yellowish and blackish color
    I put back in Amsoil 75-90 (deep yellow, browish color) it was exactaly 3 gt! I have a headlamp and it filled up to the fill plug...
    I hope I can do the transfer case tomorrow but it might rain here in NJ...
    I'm going to do the driver shaft joints, but I dont know where to put the grease into...
  14. Jan 16, 2010 at 2:37 PM
    #394
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    i did mine the other day and it was hard as hell to get the fill plug off. i sprayed some WD40 on it and let it soak in for like 30 mins. When i finally got it off i was pushing so hard on the ratchet that i punched myself in the face when i broke torque...my jaw still hurts.
  15. Jan 16, 2010 at 3:02 PM
    #395
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    that sucks dude
    I looked into my transfer case, and it looks like its leaks a little...
    I tighten it as much as I can... umm
  16. Jan 16, 2010 at 3:34 PM
    #396
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    My drain and fill plug were pretty easy. I just used my 1/2 inch drive ratchet and it had no problem getting it off. Just alittle tap with my fist and it was loose.
  17. Jan 16, 2010 at 3:38 PM
    #397
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    Ok.. So, I think ive got this down... tell me if I am missing something...
    Step One: Go to the store and buy beer
    Step Two: Call Brian
    Step Three: Open a couple beers
    Step Four: Watch Brian change differential fluid
    :rofl::rofl:
  18. Jan 16, 2010 at 5:46 PM
    #398
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats kinda how he did it. :D
  19. Jan 18, 2010 at 5:51 PM
    #399
    562Tacoma
    562Tacoma Well-Known Member
    Southern, CA (SoCal)
    08 PreRunner TRD Off Road 4x2
    -Maxtrac 4in lift spindles -5100's all the way around -Drilled and slotted rotors with ceramic break pads -Pro comp 1in AAL -17in wheels with a -6 offset (4.5 backspace) -1 - 10inch kicker comp (ported box)
    Great write up... Need to do mine as well... Anyone know how much diff oil is needed to put in? I've heard some people on here say that you are only supposed to put in a cirtain amount of diff oil, while I hear most other people say pour it in until it spills out then wait a minute then pour in oil until it comes out again then close it up... Can anyone claify this for me....
  20. Jan 18, 2010 at 5:53 PM
    #400
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3 quarts.
