Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 18, 2010 at 6:59 PM
    #401
    jandrews
    '09 FourDubDee TRD OR
    All fluid capacities are in your owner's manual. It's almost like Toyota thought you might need this information at some point and created a handy reference with it all in one place...
  2. Jan 19, 2010 at 5:44 PM
    #402
    562Tacoma
    562Tacoma Well-Known Member
    Southern, CA (SoCal)
    08 PreRunner TRD Off Road 4x2
    -Maxtrac 4in lift spindles -5100's all the way around -Drilled and slotted rotors with ceramic break pads -Pro comp 1in AAL -17in wheels with a -6 offset (4.5 backspace) -1 - 10inch kicker comp (ported box)
    Thanks for the response...
  3. Jan 19, 2010 at 7:35 PM
    #403
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    ahahahahah...nice one:) Be easy on the guy:rolleyes:
  4. Jan 22, 2010 at 5:44 PM
    #404
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So this may have been covered, but with Royal Purple oil you DO NOT need any additives for the LSD correct?
    To change both differentials and transfer case you need:
    1.1 QT 75W-90 GL-5 (transfer case)
    1.6 QT 75W-90 GL-5 (front differential)
    3.0 QT 75W-90 GL-5 (Rear differential with LSD)
    So if I just get 6 QT of 75W-90 GL-5 Royal Purple I'll be all set to change all 3?
  5. Jan 22, 2010 at 6:07 PM
    #405
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    if you have a LSD you need LSD additive. And yes 6 should be good.
  6. Jan 23, 2010 at 11:50 AM
    #406
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Ok so tomorrow I think I am going to try and change out the my diffs oil. I saw that royal purple was getting some good feed back through page 6 of this thread and I didn't feel like reading the other 15 pages. So if you have put RP in the diffs, could you all let me know what you think so far and where is the best place to buy, store or internet? THANKS!
  7. Jan 23, 2010 at 12:02 PM
    #407
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    lol
  8. Jan 24, 2010 at 7:22 PM
    #408
    Popperman63
    Popperman63 Member
    NW Arkansas
    95 Tacoma 4x4 2.7 L
    Deckplate mod, Elbow mod, Magnaflow exhaust, Toytec 3", 2" PA BL, 33x12.5R15 Kumho M/T KL71, Midland 1001z, PA, UWS Black Lo-Pro toolbox, Ext. Breather, Hella 500s, Black emblems, De-badged Tailgate, Custom rear bumper
    Found this in my rear diff...
    Thats what flowed out of the fill plug when I opened it to check the level. Looks the same in my transmission. :rolleyes: Think I should change it? lol
  9. Jan 24, 2010 at 7:23 PM
    #409
    brianr
    2010 4x4
    nice. probably glad you changed it now huh.
  10. Jan 24, 2010 at 7:34 PM
    #410
    Popperman63
    Popperman63 Member
    NW Arkansas
    95 Tacoma 4x4 2.7 L
  11. Jan 28, 2010 at 10:26 PM
    #411
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    So i am waiting for my next paycheck to buy a buncha Amsoil oils and stuff but i was under the truck the other day doing the diff breather mod and i have the LSD oil only stick on my rear diff!!!....why is this? i dont have a TRD Sport or Offroad.
    does this mean i need some addative now? and do Amsoil make that as well? (i am buying so much stuff the rep i know is giving me a killer deal so i wanna get it from him at the same time)
  12. Jan 29, 2010 at 3:29 AM
    #412
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I had the off-road edition, all i put in so far is the 3 qt of amsoil 75-90 gear oil... so far so good!
  13. Jan 29, 2010 at 7:01 AM
    #413
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As far as I know, The only Synthetic oil that the rear LSD likes is the Royal Purple.
  14. Jan 29, 2010 at 7:52 AM
    #414
    sonjay
    sonjay Well-Known Member
    Redline works fine so far with my LSD. No chatter and works grabs just as well as with the factory oil! Ask the rep if the friction modifier is in the oil already. Redline has the modifier already in it.
  15. Jan 29, 2010 at 11:31 AM
    #415
    AlexForbesR6
    Alex
    Houston, TX
    07 4x4 6-Spd
    hmmm thats interesting to know...if i still go with the amsoil how would i know if i get chatter? what does it sound/feel like?
  16. Jan 29, 2010 at 11:32 AM
    #416
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you turn, it will make a chattering/grinding sound. It may take a few miles to show up.
  17. Jan 29, 2010 at 11:35 AM
    #417
    AlexForbesR6
    Alex
    Houston, TX
    07 4x4 6-Spd
    ok...thanks chris!!!
  18. Jan 30, 2010 at 1:36 PM
    #418
    r6dink
    r6dink Member
    1. dont bother with the hose for the bottle of gear oil. I tried it and managed to get he bottle to explode all over me as I got gear oil in my eye, up my nose and in my mouth. Gagging, blowing my nose and blind... I made it to the sink. At least it was fresh oil. Just squeeze in what you can, and just put the remainder into the next bottle. You can get almost al of a bottle out sans hose wit the rear diff. so maybe do that one last.
    2. Rear diff. DEFINITELY take the tire out. Makes life SOOOO much easier. Oh and if you waited 60k miles to do the rear diff and the fluid is more like a black toothpaste you may wanna do what I did to get the most out of your$10/qt mobil1 gear oil. I ran back to the store and got the cheapest stuff they had (Coastal) and threw that in for a few miles around town and then drained it and put the Mobil 1 in. I kept the Coastal in case I have the same issue in the front.
    Did the tranny yesterday and plan on doin the front diff and the spark plugs tomorrow!
  19. Jan 30, 2010 at 1:52 PM
    #419
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's a good idea for those that are negligent in their scheduled maintenance , flushing it out with the cheap stuff. I'm going to keep it in mind in case I am derelict in my duties.:D
  20. Jan 30, 2010 at 4:39 PM
    #420
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    great thread...gonna do it next weekend. time to collect the stuff i need. last time i did this job, it was on a chevy, without a drain plug. i made a mess out of my MIL's garage. no brownie points that day.
    i got a locker, so i will try to find the royal purple, or just go with the dino stuff..i plan to stay up on the upkeep, so i will change it regularly..
