Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 27, 2010 at 10:02 PM
    #441
    bruce1271
    bruce1271 Well-Known Member
    Just changed my rear Diff today with Valvoline 80-90+lsd. Lacked up one side to get more of the old out and got about 1/3 of a cup more out. I have to say that the drain plug had about 1/4" of thick grey goo on it. I am guessing it was all small metal shavings from the gears/plates. This was my first change and is at 95K miles.
  2. Feb 28, 2010 at 6:31 PM
    #442
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Just finished mine w/ 75w90 Mobil 1 @ 30K miles. It was a pain in the friggin a$$ to get the fill plug open OMG (penetrating oil and a mallet). But after that it was a piece of cake. The oil was a disgusting gray/brown color and stunk like hell. I filled 3 qts. with out any overflow, so i got worried and checked the manual to verify -- 3 qts. it is. That oil flows SLOWWWW into the case.
    Thanks everyone for the info and experiences you have posted here. This is a kick a$$ site!!!:D:D:D
    Ted
  3. Mar 1, 2010 at 4:10 PM
    #443
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    actually now that I have driven it to work and back the ride is incredibly rough. kinda like i am driving on a gravel road. Im going to swap out to another brand.
  4. Mar 1, 2010 at 4:19 PM
    #444
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do you have a Limited slip diff?
  5. Mar 1, 2010 at 4:20 PM
    #445
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    yes metal shavings...hope you wiped them off like mentioned in the write-up.
  6. Mar 1, 2010 at 4:28 PM
    #446
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    No i dont. But the ride is horrible. My previous description is the best way i can relate the feeling. Im a little worried, but ill swap it out and see whats happening.
  7. Mar 3, 2010 at 2:15 PM
    #447
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    O.k I just reached 30,680 miles and I'm going to put in RP in the Diff sometime before Saturday. I will be traveling to Laredo about a 3 hr. drive and will be giving my opinion on the change if any when I get back. I do use RP in the motor and have never had any problems. I change it out every 5,000 miles. Thanks for all the info brianr & chris4x4!! Oh I will be changing out the sparkplugs as well, thanks for the help on that in advance chris4x4!!:) My wife is begining to like this website.....it's saving her money!!:rolleyes::D
  8. Mar 3, 2010 at 2:20 PM
    #448
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear Rob! Glad to help!
  9. Mar 3, 2010 at 2:25 PM
    #449
    rob1
    Robert
    South Texas
    No, No, No Thank YOU kind sir!!:woot:
  10. Mar 4, 2010 at 8:12 PM
    #450
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Changed it to Lucas 80w90. Rides good now thanks.
  11. Mar 10, 2010 at 3:43 AM
    #451
    markveneris
    markveneris Well-Known Member
    mark
    germany
    I have searched and searched but cannot find a writeup on how to change the front.
    Does anyone have it?
    Thanks
    Mark
  12. Mar 10, 2010 at 7:17 AM
    #452
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its simmilar to the rear, just you use a 10mm hex socket, and use 1.6 quarts. You have to remove the skid plate.
  13. Mar 21, 2010 at 2:20 PM
    #453
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    OK - don't know if this has been asked, so I'll go first.
    Bought 4 qt of 80-90 for the diff (Lucas) and 3 qt of 75-90 (mobile 1) for the tranny. Had a brain fart, and put the 75-90 in the diff. It took the 3 qts with no overflow. My questions:
    1. Is everyone doing OK with the 75-90, even in cold conditions?
    2. If there is no overflow, do I need more? Or if I get the 3 qts in am I good?
    3. Anyone need 4 qts of Lucas oil? :)
    I have the 4cyl Prerunner manual.
  14. Mar 21, 2010 at 2:22 PM
    #454
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It wont hurt anything, and the manual calls for 3 quarts even.
  15. Mar 21, 2010 at 2:31 PM
    #455
    06dak
    Central Ohio
    Chris, thank god you spend way too much time on this forum and can answer questions quickly!
  16. Mar 21, 2010 at 2:33 PM
    #456
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For the time being anyway :)
  17. Mar 21, 2010 at 2:39 PM
    #457
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    rolmfao
  18. Mar 22, 2010 at 10:17 PM
    #458
    The_Dude
    The_Dude Well-Known Member
    I think I found my answer
    Gracias!
  19. Mar 26, 2010 at 2:01 PM
    #459
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    just change my front diff, rear diff, and tc. mileage is 28,800
    rear diff took 3 quarts + 7 oz of additive
    front diff took between 1.5-1.6 quarts
    tc took 1.1-1.3 quarts
    rear diff oil was super-dirty
    front diff oil was well used, but not too bad and alot of crap on the magnet
    tc oil was nearly brand new
    also, i may or may not have over-torqued the shit out of the TC bolts
    also, the front diff is a bitch and a half to get to
  20. Mar 26, 2010 at 3:06 PM
    #460
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, the manual calls for 4 oz. of addative. You should be fine with the 7 though.
