Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 24, 2010 at 6:00 AM
    #521
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can e-mail Toyota and give your VIN number, and they can tell if you have an LS diff.
  2. Jun 24, 2010 at 7:42 AM
    #522
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I can only tell you what I would do in your situation.
    I would find level spot, unbolt fill plug and started putting oil until there is some leaking out out of the fill plug or somewhere else.
    Make sure you check your axle breather.
    The correct level is up to the fill hole. So it needs to be at that level for differential to not implode, regardless how many qt or gallons or barrels it takes you. That fill plug makes sure that around 50% of your ring with carrier is submerged in the oil for lubrication and cooling. You don't want to be much below that. And physicly is not possible to be above it when you doing that on level ground.
    Now if you like me you put truck on steep grade and overfill that sucker to the brink.:D But thats just me. (This is me and others should follow unless they doing so on their own risk)
  3. Jun 24, 2010 at 7:44 AM
    #523
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AS I stated, The FSMM clearly states to NOT fill it to the fill hole, and goes on to say that too much oil can damage the gears. The oil will cavitate, and not lubricate. The highest the oil level should be, is no closer than 5mm to the fill hole. If the truck is a Prerunner, or 4x4, the diff takes 3 quarts. If there is another issue, and there are in fact 3 quarts of oil in the diff, then there is an underlying problem.
  4. Jun 24, 2010 at 7:48 AM
    #524
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1 GM actually put out a service bulletin saying the same thing. They even had instructions on how to make a little dipstick to check that the level was within specs. I forgot what was involved, but I believe they used a paper clip.
  5. Jun 24, 2010 at 8:11 AM
    #525
    BlueT
    NorthEast
    Its again my thing. Its a choice to make and I choose not to have my pinion bearings run dry even on inclines :D
    BTW. This is how so many people screwed up their diffs, went to climb super steep incline and keep hammering with truck nose up until their pinion bearings started running dry, once you loose preload there goes the tooth on the ring and pinion. Thats why it is good to back down to a level spot to get bearings lubricated. :)
  6. Jun 24, 2010 at 11:30 AM
    #526
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Now everyone tells me.. lol..
    But I had a hell of a time finding one.. Sears didn't even have one..
  7. Jun 26, 2010 at 2:14 PM
    #527
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Just finished my rear diff! Thanks for all the info guys...TW kicks as!. I don't know what's more gratifying, a mod/upgrade...or doing my damn thing on some maintenance!
  8. Jun 28, 2010 at 10:57 PM
    #528
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    X2. I had the exact same questions. Anyone want to put in there 2c's (chris4x4 I'm hoping to hear from you)?
  9. Jun 29, 2010 at 6:36 AM
    #529
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    09's and up dont need the addative. You can use synthetic just fine in the diffs.
  10. Jun 29, 2010 at 9:48 AM
    #530
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Thanks Chris, it is a little confusing because the sticker on the rear diff said to referrer to my manual. I did that and it only says to use Toyota fluids so I called my dealer and they told me they use this http://www.mag1.com/ProductDetails.aspx?id=4d0a56b4-ab09-42b1-a240-8eac56cf7966 which I had never heard of before. They also said to make sure that I use some kind of synthetic. One last question, when do I change the transfer and front diff oils?
  11. Jun 29, 2010 at 9:49 AM
    #531
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I useually change them at the same time.
  12. Jun 29, 2010 at 9:53 AM
    #532
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Wow that was quick! Thanks for the info. I have said it before and I am saying it again; Chris4x4 you rock!!!:)
  13. Jun 29, 2010 at 9:56 AM
    #533
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
  14. Jul 6, 2010 at 2:08 AM
    #534
    08BlackTacoma
    08BlackTacoma Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    so wait a sec, I read this entire thread to realize that my 09 Double Cab LB Prerunner Sport DOES not have LSD? but from 05-08 they did have LSD? why is that?????? why would toyota take it away? I bought mobil1 for the diff, will do it tomorrow, I also bought LSD additive, can i put it in anyway? will it hurt?
  15. Jul 6, 2010 at 6:00 AM
    #535
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont put the addative in.
  16. Jul 6, 2010 at 8:17 AM
    #536
    BlueT
    NorthEast
    I guess Toyota removed mechanical LSD for the same reason they removed solid axle and front lockers... :D
    Average American consumer does not know any better, hence just call ABS a Auto-LSD and Voila people will still think they have LSD. ;)
  17. Jul 6, 2010 at 1:15 PM
    #537
    08BlackTacoma
    South Florida
    Yeah, that is such BS that toyota even calls this an Auto LSD, in no way can it actually work just like an actual LSD. In fact, they should not even be allowed to use the term LSD for this diff.
  18. Jul 6, 2010 at 1:17 PM
    #538
    08BlackTacoma
    South Florida
    Thanks Chris, and btw, after reading this entire thread, I lost count of how many times you had to tell people the diff takes 3quarts! LOL I tried counting, seriously, but could not count that high!:D
  19. Jul 6, 2010 at 2:43 PM
    #539
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lol! :)
  20. Jul 6, 2010 at 3:55 PM
    #540
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    :goingcrazy:
