Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 22, 2009 at 2:26 AM
    #41
    Motoknuckle
    Motoknuckle Braaaaap!
    Caleb
    Iowa
    02 Prerunner xtracab V6
    Tint, Clear Corners,
    I'm guessing it's pretty much the same steps for a 1st gen? I don't feel like crawling under my truck.:p
  2. Jan 22, 2009 at 5:47 AM
    #42
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I put in 1 quart of fluid first, then the 4oz. of additive, then filled until it started comming out. I capped it off, drove the truck about 40 feet, then topped off the diff with the rest of the oil. It held exactly 3 quarts 4 oz. :)
    TacomaCZman and Bravisimo like this.
  3. Jan 22, 2009 at 5:48 AM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First gen uses the same diff, just a little narrower. I think the specs call for just under 3 quarts for th efirst gens.
  4. Jan 22, 2009 at 6:12 AM
    #44
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Sweet!! Got yah, thanks!!!;)
  5. Jan 22, 2009 at 6:17 AM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should.
  6. Jan 22, 2009 at 9:56 AM
    #46
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Our Wal Mart here said they will take the oil for no charge. but have not taken it there yet to see. Our Garbage dump takes it for no charge and since Im at the dump once in awhile it works for me.
  7. Jan 22, 2009 at 10:03 AM
    #47
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    OOPS, I forgot something. I'm not sure where Chris was going to do with the old (I guess maybe I should have taken it).
    When I change my oil, I take it to the local Checker/Kragen store.
  8. Jan 22, 2009 at 10:11 AM
    #48
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    Good job guys!!! This should be stickyed or put in mods & Tutorials.
    Thanks in advance admin and mods
  9. Jan 22, 2009 at 1:23 PM
    #49
    Motoknuckle
    Caleb
    Iowa
    Right on guys!
    I'm a little reluctant to changing anything other than the engine oil, but now I'll give this a shot.:D
  10. Jan 22, 2009 at 1:52 PM
    #50
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i use mobil1.......................iwas just asking chris if he had tried synthetic royal purple, since mobil1 didnt do so well in the lsd for him(i have the locker)..........and the manual for the 06 i had and the manual for the 04 i have now say every 30k....diff fluid change.
  11. Feb 14, 2009 at 11:49 AM
    #51
    bigredscowboy
    bigredscowboy Member
    Western NC
    2000 TRD 4x4
    anyone know the hex size on the front diff for 1st gen? anyone had success getting the rear fill plug out when it was stuck?
  12. Feb 17, 2009 at 1:43 PM
    #52
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Did you guys use the Genuine Toyota LSD Additive? If not what brand did you use?
  13. Feb 17, 2009 at 1:54 PM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. We used the OEM Toyota addative. 4ozs.
    TacomaCZman likes this.
  14. Feb 18, 2009 at 4:48 AM
    #54
    jshaw
    jshaw Active Member
    Jeff
    S.C.
    06 TRD Sport White
    UWS black tool box, ScanGuage with Blend Mount, Rear AAL with 5100's all around,Total Chaos UCA's, Firestone air bags, BHLM with HID's
    Sorry to bring back an old thread but yesterday I bought Mobile 1 synthetic gear oil to change my LSD rearend this weekend. I also bought a tube of additive. I stumbled across this thread this morning and am now concerned about using it since it seems Chris had a bad experience. Has anyone come up with new results? Should I use Royal Purple synthetic or go with conventional gear oil? Thanks
  15. Feb 18, 2009 at 4:54 AM
    #55
    brianr
    2010 4x4
    As you see in our wrtie-up, I/we chose to go with conventional 75-80/75-90 "Dino" oil.
    I have read on other forums guys having problems in the LSDs' using synthetic Mobil 1, and guys having good luck with RP. Maybe it has somehting to do with the LSD additive...:confused:
    Not having the first hand experiance from using those, Chris4x4 should be able to answer better.
  16. Feb 18, 2009 at 5:55 AM
    #56
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used different combos of Mobil 1 and the Addative. I tried it with no addative, 2oz., 4oz, 8oz. Enev tried the Mobil 1 LS, which is supposed to have the addative in it or something. No luck. After a few days, the rear chirped and howled.
    Personally, If you do any towing, or get your diffs underwater, use dino oil in the diffs.You gotta change them more frequently anyway, so why spend the money. :)
  17. Feb 18, 2009 at 6:56 AM
    #57
    jshaw
    jshaw Active Member
    Jeff
    S.C.
    06 TRD Sport White
    Thanks Chris. I will use the dino oil for the rear. One more reason this is such a great, informative site.
  18. Mar 3, 2009 at 9:42 AM
    #58
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    can you use synthetic in the rear end for a 2009 sport. it has a lsd but it is electronic.
  19. Mar 3, 2009 at 1:37 PM
    #59
    brianr
    2010 4x4
    you could, yes. were you thinking of going Mobil 1 or RP?
  20. Mar 3, 2009 at 9:22 PM
    #60
    bastardk1
    bastardk1 Member
    Alton,IL
    TRD Sport 4+4
    Flowmaster Trd Intake 3 in. readylift
    Awesome How to. Got Keep Those dealerships out of your pocket. Preach on.
