Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Aug 23, 2010 at 10:05 PM
    #581
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No worries, let me know how the diff change goes :)
  2. Sep 1, 2010 at 10:13 PM
    #582
    1.21jigowatts
    1.21jigowatts Member
    SO CAL
    09 tacoma sport
  3. Sep 6, 2010 at 3:35 PM
    #583
    Vinybagodoughnuts
    Vinybagodoughnuts Member
    Vince
    Deerfield Beach,Fl
    05 trd sport sb
    Too many!!!!LOL
    Used Mobil 1 80-90W. Works like a charm. Thanks again Chris.
  4. Sep 8, 2010 at 7:02 PM
    #584
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  5. Sep 8, 2010 at 7:24 PM
    #585
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct, but the "LS" on the Mobil 1 gear lube denotes that it is safe for use in LS diffs...It doesnt have any LS addatives in it.
  6. Sep 8, 2010 at 9:40 PM
    #586
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Well, that clears that up ! I used Mobil 1 LS. They told me it was OK but I didn't know it didn't have LS additive. Thanks.
  7. Sep 9, 2010 at 5:44 PM
    #587
    RocKKer
    RocKKer New Member
    No. CA
    00 Tacoma 2WD
    Thanks for the great write up of changing the rear diff oil! I used to do all my own work but lately gotten a bit lazy, this inspired me to DIY!
    BTW dlr wants $59 to do this. I did it for ~$20 and 20 min, and I'm sure they don't use Synthetic.
    I used 2 qts Mobil 1 Synthetic Gear Lube LS 75W-90 ('00 2WD non-LS).
    This oil went in very easy, I warmed it for 10 minutes in a pail of hot water, just passing that old trick along if anyone does it while it's cold (not that it is cold now).
  8. Sep 9, 2010 at 6:23 PM
    #588
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welcome to TW! :)
    Good tip to warm the oil first. I useually leave it sit in the sun for a bit :eek:
  9. Sep 10, 2010 at 5:44 AM
    #589
    Duff Man
    Duff Man Well-Known Member
    Sean
    North Carolina
    09 TRD Off Road
    AEM CAI, Magnaflow exhaust, DT headers, all speakers replaced with (2) 10's and amp behind rear seats, color matched grill, grillcraft, projector headlights, 8000k HID's, DC Torque wheels, 3" Toytec lift, Bilstein 5100 shocks.
    Awesome write up! I just hit my 30,000 mile mark so I'm going to do this today :)
  10. Sep 12, 2010 at 3:55 PM
    #590
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Hey Chris! Thanks for the write up! I did mine today and it was so easy:D! $23 later and it sounds way more quite and more pick up and go!
    It was as easy as you said it would be!
    Thank you very Much!:D:D:D:D
  11. Sep 12, 2010 at 9:52 PM
    #591
    Larry
    Larry CARL
    CARL
    WOW!!!
    I just read 32 pages of this DIY...and it reads part like a service manual...part like a novel...and part like a reality show. LOL
    I only have 2100 miles on my SR5 Tacoma...and I can't wait to tackle these gear oil changes.
    I also have 2 years/25K miles maintenance included with the truck...but I'm still gonna do this myself. I love it! I've already changed the motor oil with Mobile-1 and a new YZZD3.
    Thanks Chris...this forum rocks...is addicting...and I have not been this motivated to wrench on a truck in years.
    :cheers:
  12. Sep 13, 2010 at 6:30 AM
    #592
    Larry
    Larry CARL
    CARL
    OK...I'm somewhat confused...
    I checked and my rear-end has a C3 sticker and no LSD sticker.
    However my window sticker says I have "Auto LSD"
    Can someone clarify???
  13. Sep 13, 2010 at 7:35 AM
    #593
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The "Auto LSD" uses the brakes to give traction to a tire needing it. You do not need an LS addative in your rear diff.
  14. Sep 13, 2010 at 7:38 AM
    #594
    Larry
    Larry CARL
    CARL
    thank you
    so...would you suggest synthetic? In both diffs and transfer?
  15. Sep 13, 2010 at 7:45 AM
    #595
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sure. Mobil 1 is a good gear lube, and readilly availible.
  16. Sep 13, 2010 at 7:52 AM
    #596
    Larry
    Larry CARL
    CARL
    thanks again
    you are a wealth of information
  17. Sep 13, 2010 at 7:44 PM
    #597
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    man that fill plug is a bitch to get off huh??? howcome it has oil on the back side the whole time i got it fianly after 10 min of cussing at it that always helps... ill do the front tomorrow. does anyone know if you can squeeze the oil in out of the bottle or do you need a pump??
  18. Sep 13, 2010 at 7:50 PM
    #598
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ive never needed a pump.
  19. Sep 14, 2010 at 10:13 AM
    #599
    Vinybagodoughnuts
    Vince
    Deerfield Beach,Fl
    05 trd sport sb
    Too many!!!!LOL
    I just soaked both the fill plug and drain plug with a little wd-40 a day before I removed them and they came out with little effort.:)
  20. Oct 4, 2010 at 7:36 PM
    #600
    Eesh
    Eesh Well-Known Member
    Canada
    2025 Tacoma Limited
    I need a quick answer here guys .. hopefully someone is online that can answer this. For the rear diff I filled it till I saw gear oil coming out the fill cap then put the cap on .. waited and came back and filled it till it came out again.
    My question is.... Do I use the same fill method for the front diff and transfer case????
