Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Dec 17, 2010 at 1:07 PM
    #621
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Never thought of that. Ebay here I come!
  2. Dec 17, 2010 at 1:13 PM
    #622
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Or I can use 15W40 Synthetic motor oil? You lying bastard!
  3. Dec 17, 2010 at 2:22 PM
    #623
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No dude. You cannot substitute Motor oil, for gear oil.
  4. Dec 17, 2010 at 4:06 PM
    #624
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Sorry, I was reading up on it, and it's viscosity equivalents are the same as a 15W40. But I'm guessing that gear oil has other shit in it correct?
  5. Dec 17, 2010 at 6:02 PM
    #625
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    F...k it just use peanut oil and save money..
  6. Dec 21, 2010 at 9:18 AM
    #626
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Thanks Chris and brianr! Just finished mine, no problems although I forgot to warm up the new oil a bit before filling. No biggie as it's about 50ºF here now, just made it take a few minutes longer than it should. 27k miles and the old oil was still pretty clear, I was surprised. Cheap insurance, nonetheless.
  7. Dec 23, 2010 at 1:22 PM
    #627
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Well, after taking the truck to a colder climate I was hearing groaning and chirping when the diff was cold. After a mile or 2 it went away. Today I changed the oil again and will post up if it helped.
    The first change I thought I was using conventional Valvoline 80w-90 gear oil and the LSD additive pictured on page one. However I experienced problems. Today I bought the cheap 80w-90 conventional gear oil and Champion LSD additive. hopefully that solves my issue.
  8. Dec 26, 2010 at 8:01 PM
    #628
    BlueT
    NorthEast
    Strange i used the same Valvoline oil with Posi Trac additive and never had problems. Maybe it was not enough additive.
  9. Dec 31, 2010 at 5:31 AM
    #629
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I want to change my transfer and diff. But I just want to make sure buy the right oil and fill to the correct levels.
    I have a 09 trd dbl cab..
    Do I fill the diff until the oil comes out the top hole? and then the transfercase, do put in 3qts?
    Thanks, I just dont want to make a big mistake. This will be my first time doing this.
    Thanks
  10. Dec 31, 2010 at 7:15 AM
    #630
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only put the amount in that the owners manual states.
  11. Jan 1, 2011 at 8:07 AM
    #631
    boxxed
    Denver, CO
    09 Off Road
    Ok thanks.. Can I just get some clairification please. I have been reading many pages on this subject. So is Royal Purple ok to use for all 3 areas (front, rear and transfer) on my 09 trd? Or is Red line, or Mobil 1 the perferd choice?
    Thank you very much for taking the time.
  12. Jan 1, 2011 at 8:12 AM
    #632
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As long as you use the correct gear lube formulation, it doesnt really matter what brand you run.
  13. Jan 1, 2011 at 8:12 AM
    #633
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I put in Redline because they make a oil in the correct weight for the Toyota's. However alot of others use Mobile 1 and some even use the Royal Purple and most have good results.
  14. Jan 1, 2011 at 9:28 PM
    #634
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Question...
    I was going to buy oil for the rear/front diff and transfer case but all the oil they had said that it had "Limited Slip" formula. Some just had LS on it. Is it ok to use this as I have an OR with locker?
  15. Jan 2, 2011 at 12:43 AM
    #635
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
  16. Jan 2, 2011 at 7:24 AM
    #636
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, You can use that. The "LS" only means that its safe for use in an Limited Slip Diff. It doesnt have the friction modifyer in it. I belive that was covered in this thread. ;)
  17. Jan 2, 2011 at 12:19 PM
    #637
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Okay thanks. I must have missed it reading at fast speeds:/
  18. Jan 2, 2011 at 5:57 PM
    #638
    boxxed
    Denver, CO
    09 Off Road
    Ok thanks, so far everything seems cool. It was very easy to do. I still have to front and tranfercase left. To cold now. Heck I even replaced my plugs same day. That was easy also.
    Next time I will try redline. I have over 100 miles withe the RP and it seems fine. I dont hear any noise what so ever.
    Glad for this forum and the people who take the time to help.
  19. Jan 3, 2011 at 9:03 AM
    #639
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    Ok so what is everybody using reclined mobile 1 or what? And is everybody using 75-90 or something different
  20. Jan 3, 2011 at 9:35 AM
    #640
    jimmyzshack
    jimmyzshack Well-Known Member
    Houma, LA
    06 PreRunner
    leveled
    Just did this yesterday i used mobile 1
